Home > Technical (L322) > Rear shocks
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
Rear shocks
Took it for an MoT test. Passed with advisories for oil misting on the rear shocks.
They look as though it's just an electrical connector, three bolts at the top and one at the bottom and Bob's your uncle. Are they really that easy to do?
I have a 2012 4.4 TDV8 Autobiography with adaptive damping.
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #599059 28th Jun 2021 10:45pm
cass
Yes, It is that easy, just make sure you support the lower arm when you remove the bottom bolt, and it is easier if you depressurise the air bag first.
Mine were “damp” for literally years before one started to actually leak.
Post #599061 29th Jun 2021 12:25am
kbald
I have also read on here that it's extremely common on these vehicles to have that and if it's just a light misting then they shouldn't need changing it's just when it's more than a misting they are bad. Current 2007 TDV8 Vogue Buckingham Blue
Post #599062 29th Jun 2021 3:06am
kbald
Found the post here https://www.fullfatrr.com/forum/topic31802...ear+shocks Current 2007 TDV8 Vogue Buckingham Blue
Post #599063 29th Jun 2021 3:11am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
did mine recently that easy and i did not have to depressurize the air bag just had another trolley jack to lift into place. less than 30 mins job done on my drive. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #599091 29th Jun 2021 9:43am
RRDunc
Think I'll leave them for a bit, then.
Thanks, chaps! Thumbs Up
Post #599177 29th Jun 2021 8:28pm
