Home > My Range Rover > 2k for 06 4.2sc |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Nice project. please keep the update and pics coming!
20th Jun 2021 7:26pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
All depends on how handy you are with the spanners I guess mate. If your competent with them then they can be cheap cars to run if you can ignore the fuel bill.
20th Jun 2021 7:48pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
First thing i would do is to bleed the coolant system of air... Them blooming SC's don't half like air locking in the coolant system! Played with one for nigh on 3 hours the other week before it would stop overheating and throwing its coolant out... |
20th Jun 2021 11:28pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
I concur, had a nightmare bleeding mine recently, resorted to having to remove thermostat housing and header tank and using hose |
21st Jun 2021 8:39am |
What's the score gents with doing the bleeding. Any tips on how too do it?
21st Jun 2021 9:54am |
Persistent, persistent, persistent… |
21st Jun 2021 10:09am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
As far as problematic coolant system bleeding, the answer may be to use a vacuum tool, found this link for BMW engines using a tool from Schwaben, but there are lots of kits available. Only problem you could have is not having a compressed air supply.
21st Jun 2021 10:14am |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
I've been very lucky with mine on both occasions I've bled it. I followed the manual to a tee and it seemed to pay off.
21st Jun 2021 11:20am |
Things like the water pump and thermostat I'll just change them anyways so I know its done so its peace of mind as well for me. Just need to get the hands dirty one weekend and look at how to replace the pump and thermo stat |
21st Jun 2021 12:58pm |
To get into the water pump you'll need to remove the fan and shroud, the shroud is a bit of a pain and the manual says to remove the air con pipe but you can manipulate it out of the way to lift the shroud up. I ordered a viscous fan spanner from PowerfulUK when I did mine.
21st Jun 2021 1:02pm |
Well well well what do we have here then too look at. Battery been on charge for 24 hours however soon as I took it off charge it dropped 1v within a few mins however when it was connected to the terminals no power what so ever. Managed to jump started it of my impreza battery. Started up straight away and tool maybe 20 mins to get to temp at around 96°c. I'm guessing the thermostat opens up here as it started to drop in temp down to 90°c for a few mins then it went upto 120°c. Turned the car off however no fan spinning throughout the whole lot so first starting point is new battery and to investigate why the fan isn't engaging. Topped up with some water too see if there's any obvious leaks however that's staying at the same level. Had this fault code appear. I know its not an iid unit but it normally pics up the basics till I get the gap unit sorted
21st Jun 2021 7:31pm |
Could well be just the viscous fan clutch failed, result if so, good luck |
21st Jun 2021 8:10pm |
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 |
Having bled my SC system twice in six years I park the vehicle with the front higher than the rear and left overnight with header tank cap off. Worked both times. Good luck. |
22nd Jun 2021 7:30am |
Good shout that one mate. Think I'll give that a try soon. Just been out and bought a new battery from halfrauds however as I'm not even home yet n I started work at 5am I'll pass on fitting it tonight how ever I did read up a failing ecm can result in a few of my symptoms but can easily be sorted by a new battery. Needs replacing anyways so no headache either way |
22nd Jun 2021 7:00pm |
