![]() | Home > My Range Rover > My L322 4.2 SC |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 583 ![]() ![]() ![]() |
The right solution as you say is to replace with a more modern module, so that may come at a later date, for now I cant justify the cost when I still have a list of more important jobs.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 ![]() ![]() ![]() |
Out of interest, what makes you think you have a vacuum leak?
Thanks David, interesting
Mikebob Member Since: 10 Jun 2019 Location: Pretoria Posts: 10 ![]() ![]() ![]() |
Hi, i have an 07 4.2SC. It was fairly poorly cared for before i got it. I have been chasing a misfire on cylinder 8 since i got it. Changed all the usual stuff but still it persisted. Kept getting the misfire code and both cat efficiency codes. Obviously the engine light was a daily occurence. Like you my cat 2 sensor readings were jumping all over the place.
David, thanks your comments made me think, if leaks are uncommon/unknown then why have I got an issue? / have I got an issue?
Have you checked what your fuel pressure is? |
Yep checked fuel pressure, but that was a while ago so I will check again, thanks Range Rover 4.2 Supercharged 2006
Yes I know, its taken me a while, but been a bit busy.
I have the spec at idle as 450kpa, so its very low |
From the manual, I found the following
I managed to do the Supercharger oil change that I promised the car since I bought it.
Finally gave in and replaced the Bluetooth module, couldn't resist when I found one on eBay for £50
conor Member Since: 27 Aug 2021 Location: London / Ireland Posts: 146 ![]() ![]() ![]() |
This is a great thread and I will be referring back to it to read in greater detail in Future.
I use Microsoft OneNote to keep a history of servicing, parts and specific jobs that I have done or need to do. I also add links to my calendar and Microsoft ToDo which sync to my mobile and other devices. Range Rover 4.2 Supercharged 2006
