Home > Maintenance & Mods (L322) > Any jack recommendations???
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I’m looking to buy a jack and some stands for my l322.
I read on other posts to get a 3 tonne jack but do you need that? You only ever jack one corner at a time so not lifting the entire car… or is the “3 tonne” classification for leavening a car of that weight?
I’m interested in the jacking height too.
What do other members recommend for a jack and stands for occasional driveway maintenance? Ideally nothing that will break the bank… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #595991 31st May 2021 6:47pm
Ffrr-lover
I have found this… it’s cheap but seems suitable?
https://www.amazon.co.uk/dp/B07YPZG4TF/ref...&psc=1 Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #595994 31st May 2021 6:49pm
Merchy
Higher weight capacity jacks will give you a better safety factor. The higher rated jacks are generally physically larger and have a higher lift ( Distance wise ) which is bloody handy when dealing with a FFRR.
Used mine yesterday to service my daughters Insignia, by the time it was up on two tonne axle stands I could use a trolley slider like the below to get under the car in total comfort, as my 3.5 tonne trolley jack will lift very high.
https://www.googleadservices.com/pagead/ac...amp;adurl=
Not cheap, but a jack like this one is a good example.
Post #596001 31st May 2021 7:11pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Recently bought one of these. Also low profile so fits under my golf..
https://www.sgs-engineering.com/tj3lp-low-...olley-jack
I also have 4 Halfords 3 tonne ratchet axle stands
Rob. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #596030 31st May 2021 11:16pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
+1 for that SGS Engineering one, I've recently changed rear shocks and lower hub bushes on my L322 and it worked a treat. Very solid and stable and easy to carry.
Hope this helps,
Stephen Thumbs Up Formerly happymadison1978
Post #596089 1st Jun 2021 12:04pm
kbald
I've got an sgs high lift 3 tonne one and some of their large axle stands. Yes you don't need a 3 tonne Jack but it's still not light to lift even with the 3 tonne Jack and there is huge suspension travel so for me I wouldn't use anything less. Current 2007 TDV8 Vogue Buckingham Blue
Post #596097 1st Jun 2021 1:08pm
knwatkins
I have an Omega 29024-PU jack. I bought it several years ago for the bargain price of £45 new. It's a great jack, but when it comes to the time to renew it, I'll probably go for the 3 tonne SGS one mentioned above.
In terms of stands, I have four of these 6 tonne ones...
https://www.sgs-engineering.com/jsr6-ratchet-axle-stands
They go from 395mm to 605mm and have a nice large footprint for stability. They are perfect for holding up the Range Rover...
Personally, I don't like using 3 tonne stands on these vehicles because you have to extend them a fair bit and the footprint isn't great. Here's a comparison of my 3 tonne stands vs my 6 tonne ones...
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #596100 1st Jun 2021 2:23pm
Ffrr-lover
Those axle stands are now on my expensive shopping list. I think the extra size is worth the expense… although out of stock at the moment. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596113 1st Jun 2021 5:21pm
Ffrr-lover
And the SGS jack too. Cheers for the responses guys Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596114 1st Jun 2021 5:24pm
Kot
Looking at the photo comparison between 6T and 3T footprint !!!!
You have made my mind up, 6T it will be. 2018 SE SDV8 4.4 Byron Blue
Post #596124 1st Jun 2021 6:59pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Another Thumbs Up for the SGS 3T, I got a good deal with a couple of 6T axle stands, it’s the not the lightest bit of kit but does the job nice and safely.
Post #596538 5th Jun 2021 7:08pm
Ffrr-lover
So following the suggestions from people, I am favouring this jack and stands combo…
https://www.sgs-engineering.com/tj3x-jsr-3...xle-stands
3 tonne jack and 2 x 4 tonne ratchet axle stands.
I believe the 4 tonne stands are enough, (although there are heavier tonnage ones available) but do shout if you think 4T isn’t enough… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #596549 5th Jun 2021 8:50pm
kbald
The 4 tonne ones will be fine. I have the 6 tonne ones and you need it up really high to start with to get them under the chassis etc to lower onto so do tend to use my 3 tonne ones more.
The trolley Jack I have is the tj3 one which goes to 520mm high so double check the one you've linked will raise it high enough with the full suspension travel though is all I'd suggest Current 2007 TDV8 Vogue Buckingham Blue
Post #596630 6th Jun 2021 3:53pm
klj
United Kingdom 2011 Range Rover Vogue 4.4 V8 Stornoway Grey
Hiu. I just got hold of an SGS 3 ton jack. After two lifts the rams are squeeling . Contacted SGS , told they needed some vid / pics? Just a few weeks old. Not impressed. Wont be using it again until sorted.... ----------------
2010 RR tdv8 3.6 ( gone but not forgotten ...)
2012 RR tdv8 4.4
2004 RR 4.4 V8 (M62) -gone but not forgotten (sob)
1998 P38 RR - least said the better
2009 BMW 7 Series 3.0d
Various motor cycles - BMW GS
1998 Jag XKr 4.0 V8
Post #598031 19th Jun 2021 2:30pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
I too have the SGS offering. No complaints as yet, but thus far has seen only limited use.
My other jack an Arcan XL30R (also 3 tonne low profile) has seen more action.
Both had key roles in the exercise to replace the starter motor earlier in the year to along with an SGS 6 ton (Imperial apparently) axle stand.
The Arcan may be hard to find.
Currently available from Amazon and listed curiously as "Model 30BL", although "XL30R" does appear in the listing text.
Recommend also the use with these of items listed variously as jack/saddle pads.
A selection available on eBay, the smaller diameter disc shapes having a raised "lozenge" section fit quite nicely the sill jacking points on the L322. The larger diameter items usually having a notch cut across the surface with perhaps another at 90 degrees to this can also be useful.
Warwick
Post #598925 27th Jun 2021 4:29pm
