![]() | Home > Maintenance & Mods (L322) > Seized bolts… what do we do before we start cutting? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
Added to the wish list ![]() Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 ![]() ![]() ![]() |
+ 1 on 6 sided sockets, even better make sure they are all impact gun grade ! Paul, 2001 Discovery 2 TD5, 211,000 miles & climbing 2006 FFRR TDV8 Vogue 151,000 miles & now sold Member of Midland (Land) Rover Owners Club, www.mroc.co.uk |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 330 ![]() ![]() |
XCP is getting good reviews. I will be buying that when I run out of WD40 |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Forget WD40 for anything other than cleaning or dispersing water. Plus Gas is a great penetrating fluid, do yourself a huge favour, buy it in bulk (5 litres) and get a pump spray bottle. Soak the offending items twice daily for a week before commencing work. Ive never had it fail. BMW i3 Electric Car
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1210 ![]() ![]() ![]() |
As for the question earlier on - 'Are there any issues with these anti seize liquids? Such as they cause problems with rubber?'
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
I’ve recently replaced all the front suspension on my 2011.
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 ![]() ![]() ![]() |
I use Normfest super crack ultra ice rust removal , never fails amazing stuff . Having spent my working life in engineering I thought I knew a bit but this stuff is magic . 2011 tdv8 4.4 vogue Santorini black |
Cheers Rob, that’s a fair comment! Obvious when you know… just not when you don’t! ![]() Does the spray leave a residue that needs to be cleaned off before putting things back together? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
Had a quick google for this… lots of pages selling the stuff but the few pages where people talk about the stuff and it’s all good! Like you say, it’s magic!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
And thank you again Merchy! Very helpful advice! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
No real residue left, will usually evaporate off. Should replace nuts & bolts with new ones. Often ball joints come with new nuts if not, order some as cheap enough. Depends on what you are replacing as to how easy it'll be, if doing the ball joints I sprayed where these went into the hub also. used a cold chisel & worked on the tab on either side working it out evenly. Took a bit of effort but wasn't as bad as I expected. Also make sure you support the weight with axle stands. Rob. 2011 (MY12) 4.4 TDV8 Vogue 2016 Golf GTI PP Gone Audi A4 VW Passat VW Corrado G60 VW Golf GTI BMW E30 Mini Vauxhall Chvette |
Thats sound engineering advice with one caveat, the friction encountered with used / rusty nuts, bolts and washers is totally different to new nuts, bolts and washers. I allow some leeway and make sure anti-seize compound is on the threads to save grief in the future. You have to take this into account though if youre going down this route. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Soaking for a few days is a great idea, that said, they are nothing like as bad a D3/4 or RRS for seizing bolts sir |
Ive read many times you should use new nuts and bolts every time, and as they are so cheap it seems silly not to! I also had a google about the reduction of torque when using anti seize… and the suggestion I found was to reduce the torque setting by 25-30% https://blog.fcpeuro.com/6-tips-for-effective-use-of-anti-seize Does that seem right to people? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
