Home > Maintenance & Mods (L322) > Seized bolts… what do we do before we start cutting? |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
I am planning to replacing some suspension parts and am expecting to be met with some seized bolts on the way.
29th May 2021 6:43am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7834 |
I’m no expert, but if that doesn’t work, I believe there are sprays you can buy to freeze it. Something about the rust bond breaking......
29th May 2021 7:41am |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1209 |
SLTH posted recently that he used this stuff, he reckoned it was very good, may be worth a try instead of WD40
29th May 2021 8:03am |
I hope that will be the case TJH1985!
29th May 2021 8:32am |
Cheers for this Merchy. I’ve watched a couple of YouTube vids recently, and a few (US based) videos mention “penetrating spray” but never showed what that was. Besides… “penetrating” snigger Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
29th May 2021 8:35am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
I use one of these, it’s either coming undone or snapping either way it’s coming out 🤣
29th May 2021 8:44am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 503 |
WD 40 is not a very good penetrating fluid.
29th May 2021 8:46am |
Ha! Yep, that’ll work!
29th May 2021 8:48am |
Perfect! Thanks Strider! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
29th May 2021 8:49am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
Make sure you use 6 sided sockets on the nuts and bolt heads, 12 sided sockets will cause you grief. |
29th May 2021 9:00am |
When working on the suspension, one of these breaker bars is very handy.
29th May 2021 9:27am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 876 |
I’ve used this with good results
29th May 2021 9:57am |
That makes sense! Thanks! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8 Past rides: 2014 Audi Q7 3.0d (good riddance) 2010 L322 Autobiography 5.0 Supercharged 2011 L320 HSE 3.0 sdv6 2014 Jaguar XF-RS 5.0 supercharged 2007 BMW 535D 2005 Mini Cooper S https://www.fullfatrr.com/forum/topic59478.html |
29th May 2021 10:54am |
Are there any issues with these anti seize liquids? Such as they cause problems with rubber? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
29th May 2021 10:56am |
