Home > My Range Rover > New to me: L322 4.4L TDV8 Vogue SE
Page 3 of 6 <123456>
bluebottle
United Kingdom 2012 Range Rover Vogue SE TDV8 Buckingham Blue
JohnW wrote:
I had a quick look, expensive books and case, I was lucky to have mine with the car and £13k+ worth of bills the previous owner did in the last 4 years.
Thanks John... I have had a look at Land Rover's own replacement docs and I might have to do it since I'll need a new service record anyway as the next one will complete the 10 spaces in the original book... 2012 L322 TDV8 Vogue SE: Buckingham Blue
2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten
Post #593988 12th May 2021 2:00pm
mjdronfield
I believe you can also have one in mph and the other in kph.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #593990 12th May 2021 2:02pm
DrRob
Digital speedo aside...an IID is a must-have to save you stacks of cash over ownership alongside the collective forum wisdom. Guarantee to save you lots of dosh Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #593993 12th May 2021 2:17pm
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Same here on the service book. I've ordered one of these https://www.ebay.co.uk/itm/313063352074 2011 Vogue SE TDV8
Post #594139 13th May 2021 2:21pm
bluebottle
My second hand GAP IID BT tool turned up in the post today. Patrick at GAP was super fast responding to the unlock email and within minutes I have already discovered that what it gives with one hand apparently is taken with the other! Rolling Eyes
So I went in to modify the CCF to give me a digital speed readout in the speedometer ring to mirror the gear selection window in the tachometer. Added one-press superlock and activated DRLs.
I find that it has cleared my FM and TV presets, in fact I can't seem to get a TV picture at all now, and it has stopped one-touch window closing and wing mirror folding.
I have read elsewhere that I just need to press and hold the window controls to reset the relay for that; but is this going to happen every time I need to do something with the tool?! 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #594808 20th May 2021 3:23pm
PeteT80
Only when you edit the CCF. You can re calibrate the windows using the IID.
Post #594809 20th May 2021 3:44pm
bluebottle
Ok cool - how about the folding wing mirrors? Is that because I've coded one-press superlock? Before they used to fold in on first press and then I'd have to press the fob a second time to get the superlock. 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #594812 20th May 2021 3:46pm
PeteT80
My mirrors do the exactly the same but sometimes fold first time. Just unlock and lock it again and they’ll fold in.
Post #594813 20th May 2021 3:52pm
bluebottle
Brilliant, thanks guys, mirrors reset themselves after unlock and lock cycle. Found the thread elsewhere on here about pulling the switches for the windows to reset that and they too now work as they should.
Next stop service on Monday. I’m mildly concerned that my turbo can be heard when driving - but is that just because I’m coming from a TD5 Defender where the engine is so loud you can’t? 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #594966 22nd May 2021 9:44am
mjdronfield
You are finding things to worry about now 🤣 I hear my turbo sometimes if I reverse up a slope and back off the throttle...
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #594980 22nd May 2021 11:35am
bluebottle
Right, service completed, I have had what they referred to as a "B Service". As far as I can make out, independents and even some JLR main dealers refer to all servicing under the Defender terminology since the manual calls Range Rover services "Oil Service" and then Inspection 1 and 2...
Anyway - changed filters for oil, air, pollen and fuel. I presume it also included an oil change?
Items noted at the bottom of the invoice:
Oil leak from rear of engine; fixed by replacement of two o-rings. (They told me this is an oil pipe fitment which LR will not supply seals and requires a whole part replacement, so they have sourced a supplier of o-rings to rectify for £2.88 instead of hundreds)
Slight play in nearside rear upper rose joint
Rear brake pipes slight corrosion
So, how worried should I be by either of those two things? I had rear brake pipes give up on me in my Defender and I ended up being brought home on the back of an AA truck because my brake fluid was in the grass on Salisbury Plain. Fortunately I was only doing 5mph when I realised and so could safely stop. 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #595207 24th May 2021 6:19pm
mjdronfield
There have been a few posts about the oil leak and those O rings. There might be a “how to” in the wiki....
Hopefully that sorts it, or it will be the oil cooler....
I had rear brake pipe split in January, and as my pedal went to the floor, it stuffed the seals in the master cylinder too. Just under £700 all in. If you are keeping it for a while, I’d get the brake pipes replaced... £250 ish I imagine.....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #595208 24th May 2021 6:27pm
mjdronfield
https://www.fullfatrr.com/forum/topic35977.html
https://www.fullfatrr.com/forum/topic48745-15.html 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #595209 24th May 2021 6:29pm
bluebottle
Thanks for that - looks like £3 well spent by my indy then!
I'll get it booked in for the brakes next then. 2012 L322 TDV8 Vogue SE: Buckingham Blue
Post #595214 24th May 2021 6:52pm
DrRob
Which independent specialist did you use? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #595218 24th May 2021 7:11pm
