Home > My Range Rover > New to me: L322 4.4L TDV8 Vogue SE |
bluebottle Member Since: 16 Apr 2021 Location: The M3 Corridor Posts: 155 |
Thanks John... I have had a look at Land Rover's own replacement docs and I might have to do it since I'll need a new service record anyway as the next one will complete the 10 spaces in the original book... 2012 L322 TDV8 Vogue SE: Buckingham Blue 2005 Defender TD5 110 XS: Cairns Blue - Gone but not forgotten |
12th May 2021 1:00pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7850 |
I believe you can also have one in mph and the other in kph.....
12th May 2021 1:02pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 |
Digital speedo aside...an IID is a must-have to save you stacks of cash over ownership alongside the collective forum wisdom. Guarantee to save you lots of dosh Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
12th May 2021 1:17pm |
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 |
Same here on the service book. I've ordered one of these https://www.ebay.co.uk/itm/313063352074 2011 Vogue SE TDV8 |
13th May 2021 1:21pm |
My second hand GAP IID BT tool turned up in the post today. Patrick at GAP was super fast responding to the unlock email and within minutes I have already discovered that what it gives with one hand apparently is taken with the other!
20th May 2021 2:23pm |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 216 |
Only when you edit the CCF. You can re calibrate the windows using the IID. |
20th May 2021 2:44pm |
Ok cool - how about the folding wing mirrors? Is that because I've coded one-press superlock? Before they used to fold in on first press and then I'd have to press the fob a second time to get the superlock. 2012 L322 TDV8 Vogue SE: Buckingham Blue
20th May 2021 2:46pm |
Brilliant, thanks guys, mirrors reset themselves after unlock and lock cycle. Found the thread elsewhere on here about pulling the switches for the windows to reset that and they too now work as they should.
22nd May 2021 8:44am |
You are finding things to worry about now 🤣 I hear my turbo sometimes if I reverse up a slope and back off the throttle...
22nd May 2021 10:35am |
Right, service completed, I have had what they referred to as a "B Service". As far as I can make out, independents and even some JLR main dealers refer to all servicing under the Defender terminology since the manual calls Range Rover services "Oil Service" and then Inspection 1 and 2...
24th May 2021 5:19pm |
There have been a few posts about the oil leak and those O rings. There might be a “how to” in the wiki....
24th May 2021 5:27pm |
https://www.fullfatrr.com/forum/topic35977.html
24th May 2021 5:29pm |
Thanks for that - looks like £3 well spent by my indy then!
24th May 2021 5:52pm |
Which independent specialist did you use? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th May 2021 6:11pm |
