![]() | Home > In Car Electronics (L322) > BCM/BCU unit replacement ..How-to.. |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 ![]() ![]() |
The following �How-to� is intended for DIY owners like me who have limited mechanical and technical knowledge. I defer humbly to our more experienced members for whom this is probably routine stuff!
This sounds easy but the locking mechanisms had me stumped and I made a complete mess of it! This is how to unclip them: Firstly, the big black connector: the �locking cover� on this has to be pushed to one side so that the lugs slide down the grooves:
If necessary, insert a flat-bladed screwdriver where shown in the pic below and, whilst continuing to pull outwards and to the side, gently �help� the plug out with the screwdriver:
The lugs should slide further along down the grooves, releasing the plug. Secondly, the 2 smaller connectors: there is a white clip locking mechanism which, when pushed to the side, �ejects� the plug (conversely the other direction �pulls� the plug firmly into the socket and locks it in place):
However, there is a clip locking pin on the �top� of the connector (i.e. facing the rear of the vehicle) which first needs to be depressed to allow the clip to move to one side:
As the locking clip is moved to the side around its axis (hidden in the body of the receiving connector), the plug is ejected. - Push the multiplugs and harnesses out of the way. You should now be able to slide out the old unit. - Insert the new BCM/BCU and connect the 3 multi-plugs in the reverse order of removal. Very important: make absolutely sure that the connectors are fully home and secure and that the cable harnesses are positioned so that there is no �pull� on the connectors, otherwise this could result in a poor connection and all sorts of electrical anomalies (as I know to my cost!). - Replace the plastic cover and secure with the 2 �turnbuckle� screws. - Reconnect the battery - Refit the seat Step 3 Connect the IIDTool and select Menu --> Service/Test --> BPM-Body Processor --> Renew ECU When the programming has finished, go back up through the menu to be able to exit the IIDTool, then disconnect. Step 4 Now you simply need to do the usual steering full-side-to-side after a battery disconnect, and perhaps re-programme any tweaks to the CCF you had previously made. And that�s it. I�m very pleased to say that my rear door unlocking and heavy steering seem to be a thing of the past, as does an intermittent rear parking sensor problem � although I don�t know if that�s just a coincidence or because of the new BCM/BCU � (Seeing as the BCM/BCU has a say in almost every electrical function on the car, I rather hope it�s not just a coincidence!) I really cannot end this without giving a special mention to the excellent service and support received from two sources: 1. The Gap Diagnostics team. Within the space of 2 days, they made available to me the special build module which automatically programmed the BCM/BCU for my model and year via my (non-BT) IIDTool. They (Pat) also patiently responded to dozens of E's I sent them as I was having all sorts of electrical anomalies (caused by the connectors not being seated properly!). These guys seem to have praise heaped on them on this forum whenever anyone has had dealings with them. What more can you say about them? Their after-sales (and technical support) service is nothing short of excellent. For anybody hesitating about buying a IIDTool, my advice is: stop hesitating, buy one, and it could pay for itself very quickly. 2. Dan at Duckworth Parts (site sponsor). I ordered my BCM/BCU on the Tuesday and it was delivered to me in France by midday on the Friday. Again, really great service, together with very competitive prices; buying from Dan gave me a saving of 20-30% compared with many of the usual parts suppliers. Highly recommended. Lastly, forum members Axle and Mattstevenson2005 deserve a mention and thanks for their help and pioneering work which encouraged me to do this job myself, thus saving ���� in garage labour costs! It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums. 20 years ownership of Solihull products, ALL GONE NOW, sniff! Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee. Previous: TD6 HSE L322 Auto FF 2.5 TDi 4-door Classic Disco II And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic Not to mention the Lada Niva before those. (I said not to mention it!) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
wiki'fied Steve, |
I am indeed honoured |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 340 ![]() ![]() ![]() |
Bebechoon,
thrillcat Member Since: 04 Jan 2018 Location: Ames, Iowa Posts: 23 ![]() ![]() ![]() |
This is a great post, and may end up coming in handy.
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 ![]() ![]() ![]() |
Just to add to this thread
Shirval Member Since: 17 Apr 2017 Location: South East Posts: 1 ![]() ![]() |
Just a thanks for including such a good level of detail. This gave me confidence to tackle the BCU on my L322 when almost everything BCU related shutdown. Main fault was BCU locked in Transport Mode. I bought the Gap IID BT Tool but although the BCU turn off Transport Mode command routine was accepted and executed the unit would not come out of Transport Mode (no matter how many battery resets). I bought a used BCU on eBay (exact same model BCU). Plugged in - selected renew BCU on Gap tool and everything immediately back up and working (so far as i can tell but main items all working).
Midlifecrisis Member Since: 04 May 2021 Location: NI Posts: 7 ![]() ![]() |
Thanks bebechoon, have to say that your post is one of the most comprehensive I've seen on any forum, I found it after a search to find how to remove the big plug from the bcu - I needed to be a bit more brutal.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3222 ![]() ![]() ![]() |
don't know what model/year you have but BCU are a straight swap (altho there are different part numbers for different years). Do you find your steering is heavy too? Can also stop the rear pax door unlocking. |
2002 L322
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 791 ![]() ![]() ![]() |
i find my steering heavy some times and the rear gate plays up some times
Hi, knares (& others!)
Tried a BCU reset
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
Is the BCU reset a Hard reset, or something different? 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
