Home > In Car Electronics (L322) > BCM/BCU unit replacement ..How-to..
Billy'sLad
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Thank you for the excellent instructions and clear photos, it made my job so much easier today 👍
Post #605664 5th Sep 2021 7:53pm
bebechoon
France
It is very gratifying that my amateur efforts have been of help to others. That was what I had intended, so thank you for your kind comments.
I was interested to read (#Balloonengineer) that this operation can be done without the need for unbolting the seat. Also that #Midlifecrisis resolved the problem with a BCU reset. (What’s that?)
The depth of knowledge and willingness to share is a major plus of this forum. I no longer have a Fatty but nevertheless I keep ‘lurking’ in the background as the discussions are so very entertaining!
Steve
 It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #605706 6th Sep 2021 9:28am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
just saw this post
to late i know but never mind
i also have this problem
i have found that its usualy the rear gate thats not home fully
just bump the lower gate with your sholder, then the top gate.
then lock the car, then unlock it and usuarly its good.
if not open the doors that you can and softly slam them closed and sholder the other doors
then lock them and unlock them, good luck
i worked this out, because one night i saw the boot light was on, yet the gate looked fully closed, i bumped the door with my sholder, off went the light and i locked it then unlocked it and it worked, the doors unlocked RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #687670 10th Mar 2024 10:08am
Midlifecrisis
I've got an intermittent problem with my 2002 3.0 diesel RR
Sometimes the rear passenger window goes down of its own accord. So far its only happened when the ignition is on, i dont come down of a morning and find the window open - not yet anyway. To get it back up normally I use the drivers door contol panel and once it's up, immediately reengage the child lock. Sometimes this doesn't work (the window refuses to budge using either the drivers door or the rear passenger door controls), and I use the IID tool to renew the BCU
Last time it happened, neither of these worked so I disconnected the battery for half an hours and then the drivers door control worked OK.
I've checked the wiring and connectors and switches as best as I can so it all points to the BCU having a fault - I got a replacement and fitted it - the trouble with that is that the key fob doesnt work the central locking.
What I didn't do was to renew the BCU with the new BCU fitted - I just swopped it back out again.
Any thoughts about the fault and would renewing the replacement BCU with the IID tool solve the central locking key fob?
Thanks
Post #687750 11th Mar 2024 8:56am
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Thanks for detailed instructions, they were quite useful when I swapped my BCU today. I did not need to recode it.
One question - when swapping BCU, I have noticed 6 pin plug that was not connected to anything. What it is used for?
I have 2005 RR HSE, US version.
Post #696202 15th Jul 2024 5:56am
knares
after my last post, i still had problems.
not being able to open the rear three doors, i started locking and double locking, unlocking and repeating it over and over, with the key.
eventually, all the door locks unlocked, all the windows and the sunroof flew open,
i got in, closed all the windows and its been good since.
for the steering, i have found, and it has took me five years to find it, i turn the ignition on, wait a couple of seconds after the steering wheel has found it position, i start the car and i have power steering.
as long as i give it that couple of seconds, it works, if i don't, it doesn't RR 2005 4.4 petrol
Post #696272 16th Jul 2024 3:54am
invisible999
So far I have not observed the same problems after BCU replaceme with rear doors/windows/tailgate - seems everything works. The only problem is that I can't lock remotely with keys - have use use physical key in door lock to lock/unlock it. Attempts to pair/re-pair key using the standard procedure did not help.
Post #697944 13th Aug 2024 1:43am
LASBAM
Germany 2007 Range Rover Vogue TDV8 Orkney Grey
@invisible999 having the same issue as you have. Do you have a solution in the meantime? Current:
- 2006 RR L322 - 3.6 TDV8
- 2022 MB AMG GT BS
- 2020 Audi Q2
Past:
- Ferrari California 30
- 2018 Abarth 595 Competizione
- 2009 Porsche Cayenne Diesel
- 2010 MB E500 Coupé
- 2005 Porsche 996 Turbo
- 2002 Porsche Boxster 986 S
- 2001 Audi S8
Post #700265 17th Sep 2024 2:39pm
invisible999
If you are asking about keys - I have not yet fixed yet. Locking/unlocking doors with physical key works fine. I recently got GAP ID Tool and it should have the capability to pair the key. Will look into this.
Post #700277 17th Sep 2024 4:44pm
knares
i bought several ECUs off a guy who was wreaking his range rover, same year as mine
i tried to fit one fore the air suspension, wrong number
now i have removed the BCM, only to find thats the wrong number too
the one i bought is YWC000921
mine is YWC000922
i know it will fit
but will it work, or will it do some damage RR 2005 4.4 petrol
Post #709619 19th Jan 2025 5:45am
