Home > In Car Electronics (L322) > BCM/BCU unit replacement ..How-to.. |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
The following �How-to� is intended for DIY owners like me who have limited mechanical and technical knowledge. I defer humbly to our more experienced members for whom this is probably routine stuff!
20th Oct 2016 3:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35292 |
wiki'fied Steve, ... - .- -.
20th Oct 2016 4:39pm |
I am indeed honoured , kind Sir It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20th Oct 2016 5:08pm |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 338 |
Bebechoon,
20th Oct 2016 6:08pm |
thrillcat Member Since: 04 Jan 2018 Location: Ames, Iowa Posts: 23 |
This is a great post, and may end up coming in handy.
16th Jan 2018 3:06pm |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 173 |
Just to add to this thread
24th Apr 2018 6:08pm |
Shirval Member Since: 17 Apr 2017 Location: South East Posts: 1 |
Just a thanks for including such a good level of detail. This gave me confidence to tackle the BCU on my L322 when almost everything BCU related shutdown. Main fault was BCU locked in Transport Mode. I bought the Gap IID BT Tool but although the BCU turn off Transport Mode command routine was accepted and executed the unit would not come out of Transport Mode (no matter how many battery resets). I bought a used BCU on eBay (exact same model BCU). Plugged in - selected renew BCU on Gap tool and everything immediately back up and working (so far as i can tell but main items all working).
4th Jan 2019 6:29pm |
Midlifecrisis Member Since: 04 May 2021 Location: NI Posts: 7 |
Thanks bebechoon, have to say that your post is one of the most comprehensive I've seen on any forum, I found it after a search to find how to remove the big plug from the bcu - I needed to be a bit more brutal.
18th May 2021 6:59am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3143 |
don't know what model/year you have but BCU are a straight swap (altho there are different part numbers for different years). Do you find your steering is heavy too? Can also stop the rear pax door unlocking. |
18th May 2021 8:03am |
2002 L322
18th May 2021 9:37am |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
i find my steering heavy some times and the rear gate plays up some times
18th May 2021 2:51pm |
Hi, knares (& others!)
18th May 2021 3:23pm |
Tried a BCU reset
19th May 2021 6:10pm |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 |
Is the BCU reset a Hard reset, or something different? 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
19th May 2021 6:28pm |
