![]() | Home > Maintenance & Mods (L322) > ENGINE SYSTEM FAULT? |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 ![]() ![]() ![]() |
Thanks again zeb. Reassuring to find another FF doing the same for no apparent reason!
Tugger Member Since: 28 Feb 2019 Location: Scotland Posts: 247 ![]() ![]() ![]() |
Just on the actuators - I see your readings don't have Bank 2 actuator value
Thanks Tugger, I’ll have another look |
Noted the following readings with engine running at idle then light revving: Boost pressure actuator Bank 1 - 0.76% down to 0.68% with revving Boost pressure actuator Bank 2 - 0.76% down to 0.68% with revving Commanded boost actuator control Bank 1 - 76.47% down to around 68% with revving Commanded boost actuator control Bank 2 - 76.08% down to around 68% with revving Does this look ok? |
Looks like both actuators are moving, which is good news - don't think that's your issue. Would suggest maybe checking again in a day or two and ideally immediately after you get another ESF warning. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Will do, thanks Tugger |
