Home > Maintenance & Mods (L322) > ENGINE SYSTEM FAULT? |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
It just likes to worry you
7th May 2021 7:24am |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Thanks Dingg1
7th May 2021 8:05am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4300 |
Defo get the codes read with a decent diagnostic.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
7th May 2021 9:53am |
Read codes with iCarsoft reader:
7th May 2021 1:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35262 |
this might be related,
7th May 2021 1:08pm |
Thanks Stan, I’ll have a read through
7th May 2021 1:30pm |
Is this likely to be caused by a split in a top intercooler hose?
8th May 2021 10:04am |
thats one of the first things i would check , underneath the hoses as well. ... - .- -.
8th May 2021 10:17am |
Thanks again Stan, a job for today |
8th May 2021 10:35am |
Both top hoses removed, cleaned and checked….both in perfect condition.
9th May 2021 9:48am |
because its an intermittent fault it could be it sticking now and again... ... - .- -.
9th May 2021 10:07am |
Thanks Stan, I’ll get the actuators checked/lubricated and go from there…..
9th May 2021 8:08pm |
Zeb Member Since: 04 Oct 2016 Location: Lincolnshire Posts: 134 |
I think what is described here is the occassional, random and very momentary popping up of the 'Engine System Fault' message which occurs as the car is turning over but actually before it has actually started. No other accompanying warning lights. Mine does this perhaps every 2-3 weeks. It started after the starter motor was replaced. As it happens when the engine isn't actually running I haven't followed it up yet. The car continues to run perfectly. I am curious as to what it might be however! |
10th May 2021 5:59am |
Thanks zeb. Yes the situation is exactly as you describe. I have had battery drain issues recently resulting in a replacement battery and a new alternator both which were not required as the drain was finally traced to fuse 49! The ENGINE SYSTEM FAULT message started at this time- I put it down to a low battery but now that the issue has been resolved the message is still randomly appearing!
10th May 2021 7:17am |
