Home > Maintenance & Mods (L322) > ENGINE SYSTEM FAULT?
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
Been going on since last year...but with Covid, we are not talking huge mikeagea..maybe 4k? I am not convinced it is anything to worry about though I must say...just one of those quirks which will be looked at on the next service!
Post #593749 10th May 2021 7:23am
kgeddes
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Thanks again zeb. Reassuring to find another FF doing the same for no apparent reason!
A bit like the P38, you learned to ignore the daily catastrophic warning messages which never came to anything! Very Happy
I’m going to have the actuators checked/lubricated and I’ll report back....
Post #593751 10th May 2021 7:46am
Tugger
United Kingdom 2009 Range Rover Westminster TDV8 Stornoway Grey
Just on the actuators - I see your readings don't have Bank 2 actuator value
Thing to do is get the live values displayed and rev it gently. You'll see the actual values follow the commanded values. IIRC from doing mine, it sits around 76% or so at idle, then when you rev it, it should drop down and the actual values on both banks should follow the commanded values (or at least try to)
One of mine was sticky and it revealed itself as the actual value staying put while the commanded value changed with revs. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Nissan X Trail 1.6TDCi Tekna
Fiat 500 1.2
Post #593768 10th May 2021 11:25am
kgeddes
Thanks Tugger, I’ll have another look Thumbs Up
Post #593776 10th May 2021 12:55pm
kgeddes
Noted the following readings with engine running at idle then light revving:
Boost pressure actuator Bank 1 - 0.76% down to 0.68% with revving
Boost pressure actuator Bank 2 - 0.76% down to 0.68% with revving
Commanded boost actuator control Bank 1 - 76.47% down to around 68% with revving
Commanded boost actuator control Bank 2 - 76.08% down to around 68% with revving
Does this look ok?
Post #594028 12th May 2021 4:55pm
Tugger
Looks like both actuators are moving, which is good news - don't think that's your issue. Would suggest maybe checking again in a day or two and ideally immediately after you get another ESF warning. 09 RR Westminster 3.6TDV8 - Stornoway Grey / Black interior - now gone (sad face)
Fiat 500 1.2
Post #594083 13th May 2021 7:35am
kgeddes
Will do, thanks Tugger Thumbs Up
Post #594091 13th May 2021 8:03am
