Home > Technical (L322) > Westfalia towing Bar
harleyman
Spain
Hi,
My L322 comes with a tow-bar that has this badge
When I bought the car in Germany I look at the VIN decoder and It show that the tow-bar was installed in the car so I thought that It was factory fitted but it sound weird to me that it does not have a Land Rover badge
Do you know if Land Rover fitted tow-bar with the westfalia badge?
Thank you 2012 Range Rover 4.4 tdv8 Autobiography
Post #592820 30th Apr 2021 6:47pm
RiverBlanche
Hi,
yes they do, I have just looked at a 4.4 and that had the same label also factory fitted
and for the D3, D4 and RRS the removable one is made by Thule
Post #592821 30th Apr 2021 6:56pm
LR fitted the westfalia tow bar to the 322 as the “factory” option, if the build sheet says it has a tow bar fitted then that is the right one. There is nothing that can't be fixed with a hammer😜😜
Post #592895 1st May 2021 5:18pm
Arbuckle
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
Yep. That is the same as on mine.
When looking at another (2010)vehicle without a tow bar, the longitudinal beams had 'Westfalia' labels on them from the factory. Forty years of progress. 1972-2012
Post #592971 2nd May 2021 6:53pm
Huntneils
United Kingdom 2009 Range Rover Autobiography TDV8 Santorini Black
I have a 2009 autobiography, the build sheet say tow bar prep, i have westfalia branded brackets underneath but no tow bar going across the rear of the car. I contacted weatfalia and they could not match up the part numbers with anything in their system. I spoke with Land Rover main dealer and they just suggested a whole new bar at £800.
Does anyone know if there is a westfalia bar that attaches to the brackets? Also anyone able to help with tow bar electrics?
Here is a photo of the brackets underneath
Post #593422 6th May 2021 9:12pm
The brackets which come on the car aren’t part of the tow bar even though they are made by westfalia.
They are removed when a tow bar is fitted and generally binned.
You need a whole bar, armature and hitch There is nothing that can't be fixed with a hammer😜😜
Post #593424 6th May 2021 9:17pm
Huntneils
Many thanks for clearing that up. I will start looking .....
Post #593434 6th May 2021 10:34pm
hbthepilot
Austria 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
hey harleyman,
any chance that you can take a picture of the fuse box? Just installed the same tow bar which I bought from a scrap yard.
Thank you
Post #593910 11th May 2021 6:18pm
harleyman
Spain
Of course,
I`m going to check the user manual an see where the fuse box is and take a picture.
I suppose this cars will have more than one fuse box
By the way, at the end I've have manage Land Rover to say that this tow bar was factory fitted so one less problem to get my car registered je je
I get those photos for you 2012 Range Rover 4.4 tdv8 Autobiography
Post #593942 12th May 2021 6:00am
harleyman
Spain
Hope this helps, if you heed anything in articular just ask
These are the ones behind the glove-box
And these photos are for the ones at the rear (The cargo area, boot)
Post #593943 12th May 2021 6:25am
hbthepilot
Awesome, that was exactly what I was looking for!! Thank you very much Cool Bow down
Post #593949 12th May 2021 7:31am
