![]() | Home > Technical (L322) > Westfalia towing Bar |
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
LR fitted the westfalia tow bar to the 322 as the “factory” option, if the build sheet says it has a tow bar fitted then that is the right one. There is nothing that can't be fixed with a hammer😜😜
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
Yep. That is the same as on mine.
Huntneils Member Since: 24 Feb 2021 Location: Oxfordshire Posts: 35 ![]() ![]() ![]() |
I have a 2009 autobiography, the build sheet say tow bar prep, i have westfalia branded brackets underneath but no tow bar going across the rear of the car. I contacted weatfalia and they could not match up the part numbers with anything in their system. I spoke with Land Rover main dealer and they just suggested a whole new bar at £800.
The brackets which come on the car aren’t part of the tow bar even though they are made by westfalia.
Many thanks for clearing that up. I will start looking ..... |
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 ![]() ![]() ![]() |
hey harleyman,
harleyman Member Since: 04 Feb 2021 Location: Madrid Posts: 73 ![]() ![]() |
Of course,
Hope this helps, if you heed anything in articular just ask
Awesome, that was exactly what I was looking for!! Thank you very much |
