![]() | Home > Technical (L322) > 2011 indicator fix? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
I'm afraid I've never seen a fix yet! Failures are few and far between... Doesn't help you though I know! |
TJRL Member Since: 07 Sep 2019 Location: Reading Posts: 198 ![]() ![]() ![]() |
Wow! £1.4k for an indicator relay? |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
Graham Nic is referring to the cost of a complete new headlight unit, which I assumed could not be opened to exchange the LED indicator unit.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35656 ![]() ![]() |
is it the indicator stalk that you are referring to or that the indicator lights not working..
Graham Nic Member Since: 11 Mar 2020 Location: Lerwick, Shetland Posts: 16 ![]() ![]() |
Hi Stan, it is the headlight unit that's faulty. I swopped over the units to eliminate the module and the fault is in the unit it's self. |
Hi, I have seen videos of fixes on earlier units ((06-09 models), so I know how to separate the unit, but there is no point in doing this unless I can get the part to replace the defective bit? My local spares shop say that there is a part number listed, but the company don't sell/stock it? Probably JLR still hold the patent/licence on the part? |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Have you tried BBA Reman? When I contacted them about a rear light? They said that they could take it apart.
Hi, thanks for the info, I will give them a shout and see if they can help? Cheers |
