Home > Technical (L322) > Charging, Discharging, Starting Help! FIXED |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Best to clear all the codes then keep an eye on any new codes.
2nd May 2021 8:37pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Thanks Graeme!
2nd May 2021 9:14pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 730 |
Do you have any physical symptoms that are a problem?
2nd May 2021 9:21pm |
Thanks for that
2nd May 2021 9:27pm |
Can I hard reset the CAR? what is the process/Impact? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
2nd May 2021 9:33pm |
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 |
There are guides on here under Wikis.
2nd May 2021 10:05pm |
Faults gone:
4th May 2021 11:10am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
Lots of the above codes are battery related... The P codes are legitimate codes... B's & U's are usually spurious codes issued when the battery volts dip during the starting procedure |
4th May 2021 7:39pm |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 |
So what needs changing to resolve this error?
4th May 2021 8:43pm |
I have not had a chance to replace it yet, but after the remap and egr closure it seem to have disappeared. That said is there a case of shoot build up etc that gets cleared with a bit of spirited driving ?
4th May 2021 9:30pm |
Charging seems to have resolved with clean up of BMS wiring.
8th Jun 2021 4:09am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
I'm not sure how you deduce the car is waking up when the voltage rises? If the car is truly waking up you would expect the voltage to fall. It wont be the FBH or the Compressor. Are you saying that when the car wakes up it connects your second battery into the circuit?
8th Jun 2021 5:38am |
It is dropping right
8th Jun 2021 6:19am |
Few learnings, will updates in a bit SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
30th Jun 2021 2:10am |
