![]() | Home > Technical (L322) > Charging, Discharging, Starting Help! FIXED |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Best to clear all the codes then keep an eye on any new codes.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
Thanks Graeme!
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 750 ![]() ![]() |
Do you have any physical symptoms that are a problem?
Thanks for that
Can I hard reset the CAR? what is the process/Impact? SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
Arbuckle Member Since: 11 Nov 2018 Location: Northants Posts: 78 ![]() ![]() ![]() |
There are guides on here under Wikis.
Faults gone:
Lots of the above codes are battery related... The P codes are legitimate codes... B's & U's are usually spurious codes issued when the battery volts dip during the starting procedure |
Mike Edwards Member Since: 13 Feb 2021 Location: Northampton Posts: 226 ![]() ![]() ![]() |
So what needs changing to resolve this error?
I have not had a chance to replace it yet, but after the remap and egr closure it seem to have disappeared. That said is there a case of shoot build up etc that gets cleared with a bit of spirited driving ? |
Charging seems to have resolved with clean up of BMS wiring.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
I'm not sure how you deduce the car is waking up when the voltage rises? If the car is truly waking up you would expect the voltage to fall. It wont be the FBH or the Compressor. Are you saying that when the car wakes up it connects your second battery into the circuit?
It is dropping right
Few learnings, will updates in a bit SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
