Home > Technical (L322) > Help with 02-05 underbody trw clips/rivets? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 |
When mine disintegrated on attempts for removal, I just used some cable ties to hold the cover up in place, wrapping them around the brake pipes and fixings. Not pretty, but did the job. .
23rd Apr 2021 10:11am |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 696 |
I think the shield is LR part number SGC000011
23rd Apr 2021 10:37am |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Yes, it is this HB1 part, but the oem number is not correct. There are three(maybe 4?) of them and there is thread inside. No idea how they plastic came over since they are large enough... And it's not two part item, just pattern inside of t30 torx to open/close them. Secured one with zip tie, broke the (plastic)thread of second and additional washer under third.
23rd Apr 2021 7:11pm |
yorkie3259 Member Since: 29 Apr 2012 Location: Bridgwater Posts: 9 |
I took the long thin cover off the change the rusty brake pipe that goes over the rear subframe. I had to cut the plastic screws off and ended up fixing it back with roofing screws into the old plastic and penny washers. Do I really have time to tinker with one of these |
26th Apr 2021 5:02pm |
