Home > Technical (L322) > Help with 02-05 underbody trw clips/rivets?
322BLL
Estonia
This left side plastic what covers brake hoses and air pipes(and also sunroof front drain exit) has come loose just yesterday. Skidding on asphalt more/less and making a lot of noise. Removed the two clips but the inside part is missing on both(what should hold the plastic cover in place). They are specific clips/rivets(turn in/out and not pull/push and inside part has pattern). And is not possible to random ones in same size. Fortunately no other info on them than trw and 6.6 or 6.2.
Post #592193 23rd Apr 2021 10:38am
When mine disintegrated on attempts for removal, I just used some cable ties to hold the cover up in place, wrapping them around the brake pipes and fixings. Not pretty, but did the job. .
Post #592196 23rd Apr 2021 11:11am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I think the shield is LR part number SGC000011
The fastener is RYG000030 according to the LRParts.Ru website (HB1 in the picture) - but the number doesn't appear correct !
You may have to contact a vehicle breaker / scrapyard to ask them for the part perhaps with a photo to help them identify it ! Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #592197 23rd Apr 2021 11:37am
322BLL
Estonia
Yes, it is this HB1 part, but the oem number is not correct. There are three(maybe 4?) of them and there is thread inside. No idea how they plastic came over since they are large enough... And it's not two part item, just pattern inside of t30 torx to open/close them. Secured one with zip tie, broke the (plastic)thread of second and additional washer under third.
If I find them somehow I will replace them all if not then one more zip tie and done.
Thanks for the info guys Thumbs Up
Post #592251 23rd Apr 2021 8:11pm
yorkie3259
United Kingdom 2002 Range Rover Vogue Td6 Alveston Red
I took the long thin cover off the change the rusty brake pipe that goes over the rear subframe. I had to cut the plastic screws off and ended up fixing it back with roofing screws into the old plastic and penny washers. Do I really have time to tinker with one of these
Post #592455 26th Apr 2021 6:02pm
