Home > Technical (L405) > L405 coolant leak - rear seats |
Nickfel Member Since: 22 Nov 2019 Location: Surrey Posts: 11 |
Hello,
6th Jan 2021 9:19pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
https://www.fullfatrr.com/forum/topic48938...olant+leak
12th Jan 2021 10:57pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Happy to report some 2 & abit years later she's still holding well |
13th Jan 2021 12:03am |
Dave8147 Member Since: 20 Apr 2021 Location: Birmingham Posts: 3 |
I have the same problem coolant leaking from under the rear seats in front of the rear axle.took it to a none dealer who specialise in LR and will do most jobs have said they don’t want to touch it as they haven’t the confidence in dropping the fuel tank etc so it’s booked in for Thursday at my local dealer I’m dreading the phone call it’s only done 38k In 5 1/2 years and had an easy life how can this happen and does anybody think I have any recourse given the low mileage |
20th Apr 2021 7:50pm |
I had the same thing happen on mine... Mine had Ali pipe to rubber hose to Ali pipe each part was about a foot long, so I simply removed the rubber pipe and replaced it with a longer one that covered the hole in the Ali pipe where the steel clip was fitted! That steel clip corroding was what made the Ali pipe corrode and then leak!
20th Apr 2021 8:13pm |
Thanks Pal I read that, guess I will have to wait to see what LR say on Thursday and then if that is the case find someone to either do the fix like you or bypass the rear matrix. RR L460 2023 HSE PHEV
20th Apr 2021 8:21pm |
unfortunately JLR techs tend not to be s creative as us mere mortals, so they will have a "procedure" to fix each issue. Even though they will have the tools and capability to repair the pipe, the book will say they have to replace it so I would doubt they will be willing to repair it the same way as Craig. any local garage should be able to effect the repair for you though There is nothing that can't be fixed with a hammer😜😜
21st Apr 2021 6:43am |
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1395 |
As you're in Birmingham I'd suggest a quick zip down the M5 to Craig would be your best option to having it sorted by someone who knows what they are doing and, more importantly, has resolved exactly this problem themselves.
21st Apr 2021 7:52am |
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 234 |
Mines just been recovered back to the main dealer for this very same fault. Thankfully it's under LR's approved warranty. Annoyingly they had it twice before the pipe basically just gave way and managed to dump 4 ltrs of coolant in about 30 miles. If its started leaking I would recommended dealing with it sooner rather than later... |
4th Jun 2021 3:59pm |
