Home > In Car Electronics (L405) > L405 TouchPro Duo No Sound |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
There is some info about this issue on the RRS forum and it says there is mention of the issue in the software update 19B. It may be worth you checking what software version you are on (I think I am on 20C) and making sure it is up to date
16th Apr 2021 10:02am |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 903 |
I see your car is a 2018 model. Is it the facelift?
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1217 |
Andy B
16th Apr 2021 11:49am |
I think you might have to have the dealer activate SOTA All LR cars from 1984
16th Apr 2021 11:52am |
Thanks Chalky
16th Apr 2021 12:19pm |
Yes sounds as if it has been enabled so they should be able to sort it out for you. Have you checked audio settings under the settings tab? All LR cars from 1984
16th Apr 2021 12:26pm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 771 |
Here are the fuses: https://www.fullfatrr.com/forum/topic58513.html
16th Apr 2021 12:43pm |
Chalky--Audio settings all checked it was the first thing I did.
16th Apr 2021 5:56pm |
It was the Amp Module that was frozen, solution was to remove Fuselink to reset system and update module.
27th Apr 2021 12:28pm |
Great! So, which FL was it? |
27th Apr 2021 12:53pm |
Adara
27th Apr 2021 7:57pm |
Thank you! I wonder whether these fuses are available as parts. The micro fuses are already hard to find... |
28th Apr 2021 6:36am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
I had to get some micro fuses a while back and ended up at an auto electrics supplier. I think it’s a case of they aren’t sold at your general auto store and you have to get a bit creative when shopping for them.
28th Apr 2021 6:40am |
I found them on aliexpress, the name is Micro M Rectangle Fuse PEC
28th Apr 2021 6:45am |
