Home > In Car Electronics (L405) > L405 TouchPro Duo No Sound
Kot
There are at least 2 types of FL fuses, for example the photo shown previous on this post shows FL8 different to FL1,FL2 and FL7. The diagram confirms FL3, FL5 &FL 17 are also same type as FL8.
Also attached shows FL16 its the 40A
This is a better picture showing the different types.
Edit--FYI Found this link for UK, some interesting info here on this type of fuse.
https://www.amazon.co.uk/dp/B08JGCKY15/ref...l&th=1
Also
https://www.advancedfactors.co.uk/fuses-13764-c.asp 2018 SE SDV8 4.4 Byron Blue
Post #592573 28th Apr 2021 8:17am
Kot
So it happened again just over 2 years from initial fault.
No sound from Radio/Nav/Phone etc etc and corresponding low battery. The amp was frozen again.
So pulled Fuse Link 16 (40A) and re-fitted after 5 sec and all good again.
Battery on charge and hoping that was the quiescent drain problem which started the same day the sound failed.
See Bulletin
https://www.fullfatrr.com/gallery/albums/u...0TOPIx.pdf 2018 SE SDV8 4.4 Byron Blue
Post #673383 14th Sep 2023 8:27pm
