Home > Maintenance & Mods (L322) > Airbag removal |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Which airbag There are lots. The last one I removed was two bolts... |
11th Apr 2021 9:23am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1348 |
Flat blade, maybe 3mm or 4mm, as you sit in the seat push the screwdriver in until resistance then lever it back towards you, that releases the catch, same on other side and bag should just lift off.
11th Apr 2021 9:26am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
good point steering wheel Current stable:
How long do you reckon it needs to be Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
11th Apr 2021 10:05am |
Needs to go in about 4 inches at a guess, so 6 inch blade should be fine |
11th Apr 2021 11:02am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3242 |
This thread has some info:
11th Apr 2021 11:11am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Can be very frustrating getting the unit off As one spring is released only to relocate when you try to remove the other one.
11th Apr 2021 11:36am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8348 |
Don't forget to stick your fingers in your ears and shut your eyes when you unplug it..... Pete
11th Apr 2021 11:48am |
