Home > Maintenance & Mods (L322) > Airbag removal
Danwilderspin
Airbag removal
Hi all I’m struggling here long thin cross head and flat head blades and can’t feel a spring is there a specific screwdriver size that work? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590847 11th Apr 2021 8:54am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Which airbag Wink There are lots. The last one I removed was two bolts...
Post #590854 11th Apr 2021 9:23am
dingg1
Flat blade, maybe 3mm or 4mm, as you sit in the seat push the screwdriver in until resistance then lever it back towards you, that releases the catch, same on other side and bag should just lift off.
Piece of Censored once you have done it before
Post #590855 11th Apr 2021 9:26am
Danwilderspin
Laughing good point steering wheel Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590856 11th Apr 2021 9:26am
Danwilderspin
How long do you reckon it needs to be Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #590863 11th Apr 2021 10:05am
dingg1
Needs to go in about 4 inches at a guess, so 6 inch blade should be fine
Post #590872 11th Apr 2021 11:02am
Weegie
This thread has some info:
https://www.fullfatrr.com/forum/topic2935....ag+removal
As has this video:
It requires a bit of fiddling to make contact with the end of the spring as if you push the tool in to far it passes the end to be compressed. John
GAP iiD BT
Post #590874 11th Apr 2021 11:11am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Can be very frustrating getting the unit off Big Cry As one spring is released only to relocate when you try to remove the other one.
I filed a V in my screwdriver, to enable the release spring location. I'm sure that there are other posts on here, that explain the process clearer.
Post #590876 11th Apr 2021 11:36am
Don't forget to stick your fingers in your ears and shut your eyes when you unplug it..... Shocked Pete
Post #590877 11th Apr 2021 11:48am
