Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 579 |
Smoke test showed big leak on brake vacuum hose where it meets the manifold, So I'll get a visual on that in the next few days (its supposed to be warming up a little) and get one ordered.
7th Jan 2021 3:58pm |
Yes I know its been a while, but lockdown has meant very low mileage......
7th Apr 2021 2:23am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
1) do you have lpg?
9th Apr 2021 11:03pm |
Thanks for responding
10th Apr 2021 12:56am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
Don't think it's worth messing about trying to read what the lambdas are reading, cheap enough to just change both...
10th Apr 2021 9:44am |
Agreed however the cheaper cars I have had on the past have been ok up until say 4000rpm where the mot tester is going up to but can’t cope above so start to stink.
10th Apr 2021 1:41pm |
Always used Magnaflow, never had any problems.. Pete
10th Apr 2021 3:33pm |
RR_supercharged_702 Member Since: 20 Jun 2021 Location: Las vegas Posts: 18 |
I'm have the same issue and did you end finding the issue?
20th Jun 2021 10:53pm |
Hello,
20th Jun 2021 10:58pm |
Smoke test it you either have an air leak or most likely a sensors malfunction in the maf or o2 sensors Current stable:
21st Jun 2021 7:59am |
Ok ill get it smoke test, I called the dealership to get it diagnosed it they said they're aren't able to do it because of the year and they aren't able to fix it also crazy right the dealership too.
21st Jun 2021 10:10pm |
I changed all of that - and there’s a breather I think a circular bit of plastic which was leaking - also and I bet yours has done this - there’s a little pipe that goes between the s/c output plate to the fuel pressure sensor - the pip goes floppy and blows off - another air leak. Also the concertinas between the air coolers and charger plate - both leaking too. Changed all this then it ran rich… then I changed the coils and plugs now it’s all good. Current stable:
21st Jun 2021 10:52pm |
I think that I have fixed the P0171 error by resetting the engine adaptations,
22nd Jun 2021 1:16am |
@bigbo What is engine adaptations? Where is that located?
22nd Jun 2021 1:30am |
