![]() | Home > Maintenance & Mods (L322) > P0171 on 2006 Supercharged |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 608 ![]() ![]() ![]() |
Smoke test showed big leak on brake vacuum hose where it meets the manifold, So I'll get a visual on that in the next few days (its supposed to be warming up a little) and get one ordered.
Yes I know its been a while, but lockdown has meant very low mileage......
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
1) do you have lpg?
Thanks for responding
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8568 ![]() ![]() ![]() |
Don't think it's worth messing about trying to read what the lambdas are reading, cheap enough to just change both...
Agreed however the cheaper cars I have had on the past have been ok up until say 4000rpm where the mot tester is going up to but can’t cope above so start to stink.
Always used Magnaflow, never had any problems.. |
RR_supercharged_702 Member Since: 20 Jun 2021 Location: Las vegas Posts: 18 ![]() ![]() ![]() |
I'm have the same issue and did you end finding the issue?
Hello,
Smoke test it you either have an air leak or most likely a sensors malfunction in the maf or o2 sensors Current stable:
Ok ill get it smoke test, I called the dealership to get it diagnosed it they said they're aren't able to do it because of the year and they aren't able to fix it also crazy right the dealership too.
I changed all of that - and there’s a breather I think a circular bit of plastic which was leaking - also and I bet yours has done this - there’s a little pipe that goes between the s/c output plate to the fuel pressure sensor - the pip goes floppy and blows off - another air leak. Also the concertinas between the air coolers and charger plate - both leaking too. Changed all this then it ran rich… then I changed the coils and plugs now it’s all good. Current stable:
I think that I have fixed the P0171 error by resetting the engine adaptations,
@bigbo What is engine adaptations? Where is that located?
