Home > Maintenance & Mods (L322) > design pack exhaust trims |
I don’t have the design pack on mine admittedly, but they look a different shape.... might be wrong.
5th Apr 2021 3:17pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
They look pretty much the same shape but I didn’t have the catch cans on the back of the originals they were originally blanks and I took the plate out. I’ve had them recoated once about 3 years ago just thought these may last longer Current stable:
5th Apr 2021 3:31pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35267 |
yours look the wrong way round and upside down Dan... ... - .- -.
5th Apr 2021 3:49pm |
I wondered that as well Stan, but wasn’t sure enough to suggest it.
5th Apr 2021 3:55pm |
I wish they were but the bolt holes are only in one place I will take a pic close Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
5th Apr 2021 6:55pm |
Sounds like you need a Plan B, involving the original ones, if nobody comes along with better help....
5th Apr 2021 7:04pm |
If the mounts on the trims are warped from heat could this cause my issue?
5th Apr 2021 7:21pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
Without seeing all the bits - assuming that the bolt holes are in brackets fixed to the new tips, then enlarge the bolt holes a little and bolt on, using bigger washers if needed, may give you 'wiggle' room to adjust the position.
5th Apr 2021 7:27pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1386 |
I would suggest buying genuine ones rather than cheap copies, that might be your problem. |
6th Apr 2021 9:06am |
The original ones I have seem to mount the same now they have come off which I why I'm now thinking the mounts have warped the heat and I disturbed them. Current stable:
6th Apr 2021 9:07am |
Ok a minor update - I got my powerfully trim replicas abs they looked almost identical except had slightly bigger clips...
9th Apr 2021 11:07pm |
Ok update
26th Apr 2021 10:01pm |
That’s much better.
26th Apr 2021 10:11pm |
Sorted
26th Apr 2021 10:26pm |
