![]() | Home > Maintenance & Mods (L322) > design pack exhaust trims |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I don’t have the design pack on mine admittedly, but they look a different shape.... might be wrong.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
They look pretty much the same shape but I didn’t have the catch cans on the back of the originals they were originally blanks and I took the plate out. I’ve had them recoated once about 3 years ago just thought these may last longer Current stable:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35486 ![]() ![]() |
yours look the wrong way round and upside down Dan... ... - .- -.
I wondered that as well Stan, but wasn’t sure enough to suggest it.
I wish they were but the bolt holes are only in one place I will take a pic close Current stable: 2006 BMW M6 2007 4.2 V8 S/C FF Gone: 2002 4.4 V8 FF |
Sounds like you need a Plan B, involving the original ones, if nobody comes along with better help....
If the mounts on the trims are warped from heat could this cause my issue?
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
Without seeing all the bits - assuming that the bolt holes are in brackets fixed to the new tips, then enlarge the bolt holes a little and bolt on, using bigger washers if needed, may give you 'wiggle' room to adjust the position.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1435 ![]() ![]() ![]() |
I would suggest buying genuine ones rather than cheap copies, that might be your problem. |
The original ones I have seem to mount the same now they have come off which I why I'm now thinking the mounts have warped the heat and I disturbed them. Current stable:
Ok a minor update - I got my powerfully trim replicas abs they looked almost identical except had slightly bigger clips...
Ok update
That’s much better.
Sorted |
