Home > Technical (L405) > Lower suspension arms and bushes L405
goddo
I wonder if you can help me here.
My 2014 L405 is having the front suspension lower arms with ball joints and bushes replaced by an Indie.
Apart from maybe tracking, does the whole steering geometry need resetting, please ?
Post #590103 3rd Apr 2021 11:59am
It’s probably not urgently needed as there isn’t any adjustment on the lower arms. They are just bolt on.
However that said it depends on if the camber has ever been adjusted on the top mount and if this was done with the worn lower arms. It’s worth getting it on a 4wheel machine periodically in any case just to check. These cars are so sensitive to tracking setup that just doing the toe may throw other things out, and for the sake of a few quids to have it done properly it will save on tyres in the long run.
4 wheel machines are becoming more common place now, it’s just finding a decent place who know how to use them properly. There is nothing that can't be fixed with a hammer😜😜
Post #590112 3rd Apr 2021 1:41pm
goddo
Thanks Northernmonkey, just the reply I had hoped for.
I'll start looking for a decent company to carry out a full check.
Post #590124 3rd Apr 2021 4:13pm
Where are you located goddo?
Post #590168 3rd Apr 2021 10:44pm
goddo
South Bucks, not far from High Wycombe.
I located a garage in Cressex Industrial Estate called Adams & Page.
Never used them obviously but thought I might drive round there and have a word with them.
Unless you have a better recommendation?
Thanks Craig
Post #590180 4th Apr 2021 6:51am
