![]() | Home > Maintenance & Mods (L322) > Squeaky noises - rear wheel |
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 ![]() ![]() ![]() |
Hello can somebody point me what these squeaky noises cold be?
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
hi,
thank you i will look at these bushes, could you please confirm for me if this axle bush is what you mean?
Yes, that's the squeaky bush that produced all of the noises in my car, and I could also feel it loose when I shaked the rear wheel by hands. |
its this one right? Is it safe to change it without damaging car geometry?
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8679 ![]() ![]() ![]() |
I think the nut is the alignment, so changing it will throw out the geometry (camber) a bit. You can mark the bolt and nut position on the arm so when you put the new one in it is in the correct place.
Thanks already marked position before and tried to lube both bolts and nuts all with bronze vaseline/lubricant but nothing changed :/
I’m not sure, but I don’t think they do.
mandelbug Member Since: 06 Mar 2017 Location: London Posts: 40 ![]() ![]() ![]() |
I got the bush from Island 4x4 when I did mine, didn't come with the bolt I had to order it, but it ended up the wrong bolt so didn't use it. There is a good guide on the Wiki for changing them that I followed, bought myself a Chinese bush tool set (2 cups and a long threaded bar) from the bay of E. Worked well, although I didn't have exactly the right size so now it's more cone shaped than cylindrical. |
