Home > Maintenance & Mods (L322) > Squeaky noises - rear wheel |
sergeiicz Member Since: 20 May 2020 Location: Caslav Posts: 47 |
Hello can somebody point me what these squeaky noises cold be?
27th Mar 2021 2:16pm |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
hi,
27th Mar 2021 9:32pm |
thank you i will look at these bushes, could you please confirm for me if this axle bush is what you mean?
1st Apr 2021 10:30am |
Yes, that's the squeaky bush that produced all of the noises in my car, and I could also feel it loose when I shaked the rear wheel by hands.
1st Apr 2021 10:47am |
its this one right? Is it safe to change it without damaging car geometry?
1st Apr 2021 3:09pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8503 |
I think the nut is the alignment, so changing it will throw out the geometry (camber) a bit. You can mark the bolt and nut position on the arm so when you put the new one in it is in the correct place.
1st Apr 2021 5:15pm |
Thanks already marked position before and tried to lube both bolts and nuts all with bronze vaseline/lubricant but nothing changed :/
1st Apr 2021 5:37pm |
I’m not sure, but I don’t think they do.
1st Apr 2021 7:42pm |
mandelbug Member Since: 06 Mar 2017 Location: London Posts: 40 |
I got the bush from Island 4x4 when I did mine, didn't come with the bolt I had to order it, but it ended up the wrong bolt so didn't use it. There is a good guide on the Wiki for changing them that I followed, bought myself a Chinese bush tool set (2 cups and a long threaded bar) from the bay of E. Worked well, although I didn't have exactly the right size so now it's more cone shaped than cylindrical. |
2nd Apr 2021 10:42am |
