![]() | Home > General > What Did You Do In Your Full Fat Today |
Andygriff73 Member Since: 29 Jul 2018 Location: Ellesmere Port Posts: 68 ![]() ![]() ![]() |
Fitted the towbar today with a little help from the old engine crane.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 594 ![]() ![]() ![]() |
Changed a dodgy coolant hose by the oil cooler
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 189 ![]() ![]() ![]() |
Changed front, rear axle and transfer box oil. |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Fitted my Direct4x4 Raptor sidesteps.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1453 ![]() ![]() |
This was actually yesterday but took my new one on a round trip to Bath to collect Son from Uni.
=dj= Member Since: 24 Oct 2020 Location: New forest Posts: 67 ![]() ![]() ![]() |
After a thorough wash, I finally did my duty and appeased the forum gods:
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Bought the trailer home again and finally figured out why the trailer lights don't work properly. The led lights are faulty but they have fog lights, reverse lights built in.
Daughter and I spent this afternoon fitting my new side steps to the AB. Fairly straightforward but need to source some new trim clips to refit the lower front wing panels |
Edgey808 Member Since: 17 Apr 2016 Location: U.K. Posts: 48 ![]() ![]() ![]() |
Birthday pressie fitted......
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Re-fitted my DPF would have been a lot easier with a second person, at my age my octopus skills are not what they used to be |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Used up half a tank of fuel going to four different equestrian shops. Trying to find half chaps and a helmet for myself. Finally found a helmet big enough for my 65cm circumference. Was nice driving around. |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 ![]() ![]() ![]() |
All 4 discs and pads, well I did it yesterday but was too knackered to type when I’d finished. All good on the front thanks to the guides here. The back was a different story, one disc almost welded on and one calliper seized, I can’t believe it passed its MOT 6 weeks ago. Got them working for now but a pair of replacement rear callipers are on the cards |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Happy Easter all,
Killed the battery on the range rover as I was using it to check the lights all day but that task is finally sorted with the rewiring.
