Home > In Car Electronics (L322) > 2006 3.6 Bluetooth not working
garyRR
I was going to go ahead and purchase the Nokia Bluetooth for my car then, noticed it already has it.
I checked the configuration on the screen and it's programmed for it but, in the infotainment menus, when I press 'Phone', it just says 'no phone fitted'.
Looking in the infotainment bay, I can see the Nokia system, with what looks like a multiplug missing? I also have that fibreoptics cable plug, which I have joined together.
I presume it's not working because there's a multiplug from somewhere missing or, it's supposed to be connected to whichever unit was in the place where there are now sticky pads. Can anyone take a photo of what it's supposed to look like / illude me to what's missing?
Post #589407 28th Mar 2021 10:13pm
dhallworth
The white cables that you have taped together form part of the fibre optic ring and should go in and out of your phone module.
That’ll be why it’s not showing on the screen. Chances are the module has packed in and thats why the cables have been looped together.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #589412 28th Mar 2021 11:39pm
garyRR
I have the original plug for those fibre optic cables however, that doesn't match the shape of the empty socket on the phone module?
Post #589414 28th Mar 2021 11:50pm
dhallworth
That’s odd.
Those cables not being connected is the reason that your car isn’t seeing the phone though.
I’ve just fitted a 2011 onwards module to my 2007 car, from the blue plug I’ve taken a +ve and -ve feed, that’s all. The data is transferred using those 2 fibre optic cables.
Post #589415 28th Mar 2021 11:53pm
garyRR
Do you know what's missing where the white sticky pads are?
Post #589416 28th Mar 2021 11:59pm
dhallworth
If your car is a Vogue SE, it’s where the DVD change would be I believe.
Post #589418 29th Mar 2021 12:02am
garyRR
Weirdly, it's a Vogue but, in SE spec. The only thing it doesn't have is the rear headrest entertainment.
The CD changer is in the front upper glove box. Does that not do DVD (not that anyone would these days)?
Post #589419 29th Mar 2021 12:07am
Chris1573
Hi Gary, unplug the multi pin plug on your bluetooth module, looks for signs of blue corrosion on the pins... L322 2007 TDV8 3.6
Post #589423 29th Mar 2021 12:32am
Chris1573
Post #589424 29th Mar 2021 12:33am
dhallworth
If you've not got rear seat entertainment then you won't have the 6 DVD changer.
The CD changer is in the glovebox, the DVD changer is in the boot.
This was the plug on my bluetooth module. When I opened it up the insides were much, much worse.
Post #589443 29th Mar 2021 9:29am
garyRR
Thank you.
Do you have a photo of the fibre optics plugged in, as I can try this first before taking anything apart?
Gary
Post #589446 29th Mar 2021 9:45am
TJH1985
If it turns out to be the module, I have one from a 2007 VSE for sale no corrosion at all Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #589447 29th Mar 2021 10:05am
garyRR
I have tested tonight and the module is dead.
I had blue on the pins and, after cleaning up and trying, there was still no sign of life.
So, aside from a replacement unit, what are my options? Were the Nokia units any good / microphone quality / compatibility with modern phones?
Post #589567 30th Mar 2021 6:05pm
dhallworth
The Nokia one isn’t great when it comes to connecting newer phones, occasionally you need to reconnect the phone every time you get in the car.
I’ve just changed my Nokia one for a 2012 one. The call quality is much better and you get the signal strength and phone book displayed on the screen too.
Post #589583 30th Mar 2021 7:26pm
garyRR
Maybe the newer one then. I think the part is 8H2210F845AA .
Post #589630 31st Mar 2021 8:42am
