Home > In Car Electronics (L322) > 2006 3.6 Bluetooth not working |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3074 |
The white cables that you have taped together form part of the fibre optic ring and should go in and out of your phone module.
28th Mar 2021 11:39pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
I have the original plug for those fibre optic cables however, that doesn't match the shape of the empty socket on the phone module? |
28th Mar 2021 11:50pm |
That’s odd.
28th Mar 2021 11:53pm |
Do you know what's missing where the white sticky pads are? |
28th Mar 2021 11:59pm |
If your car is a Vogue SE, it’s where the DVD change would be I believe.
29th Mar 2021 12:02am |
Weirdly, it's a Vogue but, in SE spec. The only thing it doesn't have is the rear headrest entertainment.
29th Mar 2021 12:07am |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 |
Hi Gary, unplug the multi pin plug on your bluetooth module, looks for signs of blue corrosion on the pins... L322 2007 TDV8 3.6 |
29th Mar 2021 12:32am |
29th Mar 2021 12:33am |
If you've not got rear seat entertainment then you won't have the 6 DVD changer.
29th Mar 2021 9:29am |
Thank you.
29th Mar 2021 9:45am |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
If it turns out to be the module, I have one from a 2007 VSE for sale no corrosion at all Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
29th Mar 2021 10:05am |
I have tested tonight and the module is dead.
30th Mar 2021 6:05pm |
The Nokia one isn’t great when it comes to connecting newer phones, occasionally you need to reconnect the phone every time you get in the car.
30th Mar 2021 7:26pm |
Maybe the newer one then. I think the part is 8H2210F845AA . |
31st Mar 2021 8:42am |
