![]() | Home > Technical (L322) > M62 4.4 Coolant leak from cap |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
Basically, open loop is where the engine runs solely from the ECU map, when the loop closes the engine measures the mixture from the lambda sensors and adjusts the fuel accordingly, trimming the fuel map...
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 595 ![]() ![]() ![]() |
So, replaced the leaking hose and expansion tank cap today. Flushed the system and renewed coolant. Then did 100+ Km on the new air struts.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 770 ![]() ![]() ![]() |
i know the feeling RR 2005 4.4 petrol Any spelling mistakes are the fault of spellchecker Previous MG J2, CITROEN light 15 x 2 gone unfortunately Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar |
