Home > Technical (L322) > M62 4.4 Coolant leak from cap
Page 3 of 3 <123
Basically, open loop is where the engine runs solely from the ECU map, when the loop closes the engine measures the mixture from the lambda sensors and adjusts the fuel accordingly, trimming the fuel map...
When cold it stays in open loop to be able to richen the mixture (old style choke)
This control is usually switched by the temp of the water in the engine so if you lower it too far the engine will never close the loop... I couldn't find any reference to the temp at which this happens on a fatty but as usual if you modify something you have to consider the ramifications...
I hope that makes sense.... Thumbs Up Pete
Post #589331 28th Mar 2021 9:58am
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
thanks, yes it makes sense
sort of hahaha RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #589374 28th Mar 2021 3:02pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
So, replaced the leaking hose and expansion tank cap today. Flushed the system and renewed coolant. Then did 100+ Km on the new air struts.
No leaks whatsoever.
Literally looking for excuses to drive the fatty as much as possible right now Laughing
I'm over the moon!
Post #589560 30th Mar 2021 5:07pm
Thumbs Up Thumbs Up Pete
Post #589577 30th Mar 2021 7:09pm
knares
vs322 wrote:
So,
I'm over the moon!
i know the feeling RR 2005 4.4 petrol
Post #589634 31st Mar 2021 9:25am
Page 3 of 3 <123
