Home > Technical (L405) > Battery Conditioner - Where to connect
goddo
Cam-Tech-Craig wrote:
Very strange! I have a JLR CTEK kit and guess where it connects Whistle Whistle Whistle You guessed it, in the boot on the main battery terminals... There is a small cigar lighter charger port in the RHS boot panel... Thumbs Up
Craig, my Ctek came with a pair adaptor of leads that I fixed to the battery posts and I then leave it insitu. If the battery needs a charge, I just plug the charger in. Job done! You can buy the leads as an extra on fleabay.
Post #589334 28th Mar 2021 11:05am
Boatmechanic
Sweden
goddo wrote:
I hear what you say.
Can someone explain why there should be a problem with direct connection to the battery?
If there is a problem, I would like to be aware so that I don't cause damage to other parts in the future.
When I had a Bentley Continental GT the dealership connected me up the same way?
Service manual says that connecting to battery can damage the BMS module that sits on the negative battery terminal.
You should have kept the Bentley for driving around town.
Post #589368 28th Mar 2021 3:39pm
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Here is where I access mine, extra long ctek lead, connected to the posts under the bonnet, then tucks away under the bonnet when not in use
 2013 Range Rover Autobiography 4.4 SDV8
Previous:
AMG C Class
AMG GLA
AUDI RS6
NISSAN GT-R x 5
Post #589552 30th Mar 2021 4:34pm
