Home > Off Topic > Garage Workshop.
Page 4 of 5 <12345>
DrRob
Advice needed. Best thing to do to a concrete floor to make it nice in a garage. I want an easy solution please. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589082 26th Mar 2021 8:44pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Interlocking rubber tiles Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #589083 26th Mar 2021 8:46pm
DrRob
Tried that. Not happy.
Anything I can pour and self level itself? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589086 26th Mar 2021 8:55pm
Weegie
Search "self-levelling concrete". John
GAP iiD BT-Sold
Post #589162 27th Mar 2021 9:43am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Easiest solution, get someone else to do it for you Smile Nothing better than sipping your coffee and play the Xbox whilst someone else is breaking out a sweat 🤣
Post #589164 27th Mar 2021 9:50am
V8_Disco
What depth do you have to play with?
Post #589171 27th Mar 2021 10:20am
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
Dr Rob i PVA'd mine first after sweeping and hoovering then 2 coats of floor paint from Screwfix.
as the weather was so cold each coat was left 7 days to cure fully i will post a pic later. 1 5l tin did 2 coats on a single garage 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #589172 27th Mar 2021 10:31am
DrRob
Sounds good. Please post pictures and link to the paint stuff Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589193 27th Mar 2021 12:15pm
Jayk69
Rob,
pics below.
1) sweep and hoover garage floor
2) PVA 10 parts water to 1 part PVA leave 24hrs to cure
3) Hoover floor again then Paint with roller. depending on temp it can take 7 days to fully cure. Also leave door open fumes make you feel happy Shocked Mr. Green
Link to Paint https://www.screwfix.com/p/leyland-trade-h...5ltr/88106
Post #589202 27th Mar 2021 12:53pm
DrRob
Cool. What is PVA? Link please Bow down
How do you apply it? Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589250 27th Mar 2021 4:56pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
The SC is living outside during building a boat.
Post #589253 27th Mar 2021 5:28pm
Jayk69
It is Glue the same stuff kids use for craft
https://www.screwfix.com/p/no-nonsense-pva-5ltr/57248
As mentioned above mix it with water 10 parts water to 1 part PVA mix really well. I just tipped a puddle on the floor them spread it with a roller Thumbs Up 2012 Vogue 4.4 TDV8 - Current
Post #589255 27th Mar 2021 5:43pm
It’s to seal the floor and reduce suction on the coating from the substrate ie concrete.
Basic PVA will do the job and it’s cheap and fine on a dry floor. However PVA remains water soluble even after drying, so if the floor doesn’t have a DPC under it or is fairly newly laid then it’s advisible to use an SBR primer instead which isn’t water soluble once cured. There is nothing that can't be fixed with a hammer😜😜
Post #589257 27th Mar 2021 5:52pm
@Piet - Fab boat.
My wife's Dutch. We've had a couple of boating holidays in Friesland. Would like to do it near Rotterdam also.
Post #589445 29th Mar 2021 10:37am
p38arover
Australia
I have a triple garage. We've lived here for the past 38 years and I haven't had a car, except a Hillman I was restoring, in the garage. My motorcycle is in there, though.
It's all workshop and storage. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #589453 29th Mar 2021 12:50pm
Page 4 of 5 <12345>
