![]() | Home > Maintenance & Mods (L322) > New brakes have arrived |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Another thought
ffaffage Member Since: 12 Aug 2019 Location: Hampshire Posts: 19 ![]() ![]() |
Just did a full set of pads on mine.
I'm guessing it should be something like this:- https://www.ebay.co.uk/itm/LASER-TOOLS-709...3051497708 LASER TOOLS 7097 Front Brake Carrier Bolt Socket 21mm Land Rover I saw that bolt on mine, and was a bit concerned until I realised I didn't have to pull the caliper to replace the pads. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Is that Laser Tool the right one to remove the calipers on a 2011 with Brembo? ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
IIRC a standard multi point socket will fit and undo them, not a HEX, but one which goes on may ways round. I can't remember the size tbh but the one in my drawer did the trick.
Yep but also need the size now before doing the job |
Cant help there.... cars gone. Might be the same as the 405 but not 100%👍🏻
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The sockets and ring spanners are known as double hex or 12-point. |
Thanks. Yep, just need the size |
dalex Member Since: 24 Nov 2018 Location: Suffolk Posts: 5 ![]() ![]() |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
2014 L405 TDv6 front TRW 19” callipers - front discs and pads fitting info on this link: https://www.fullfatrr.com/forum/topic63053.html Last edited by pld118 on 3rd Apr 2022 6:39am. Edited 1 time in total |
Shaunj69 Member Since: 25 Feb 2022 Location: Bristol Posts: 57 ![]() ![]() ![]() |
Hello The reason to allow the excess brake fluid through the bleed nipple is 2 fold. 1 If the fluid is forced to quickly back to the brake fluid reservoir, then there is a danger of the seals in the master cylinder flipping. This will show up as a soft brake peddle. 2 By allowing the OLD brake fluid out of the caliper, this will then be replaced with more fresher fluid. Also you can then test that fluid for water content. sorry to jump on this post but!!! |
No, the 405 tdv6 has TRW type callipers so will be basically the same procedure as the rears on a 322 or fronts on a non brembo car. Still pretty easy though. There is nothing that can't be fixed with a hammer😜😜 FFRR 4.4 SDV8 Autobiography Santorini Black. KIA E-Niro 4+ 2021 Discovery 5 D300 MHEV commercial |
