Home > Technical (L322) > Brakes replaced but now... I have no braking! |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
It's possible on some cars to flip the seals in the master cylinder whilst bleeding brakes. It depends on the design what the symptoms are but it sounds like it may be a possibility, depends how rough they were bleeding the brakes / pushing pistons back. BMW i3 Electric Car
23rd Mar 2021 7:24pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7796 |
I’m not a brake expert personally, but when I stuffed the seals in my master cylinder, the pedal went soft, though I also had a bust brake pipe at the time.
23rd Mar 2021 7:31pm |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 689 |
Your description of the symptoms sounds very odd :
23rd Mar 2021 8:05pm |
Yep, back to the people that broke it is the best solution.
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1465 |
I do feel a little overwhelmed.
23rd Mar 2021 8:26pm |
So are you saying that it was the seller who did the brake work, and you can’t really go back there?
23rd Mar 2021 8:55pm |
No, the seller sold it, took my money then disappeared into thin air!
23rd Mar 2021 8:58pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3143 |
think you need to name the fake dealer so no-one else makes the same mistake with them. |
23rd Mar 2021 11:25pm |
Done!
23rd Mar 2021 11:29pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1183 |
First stop should be to have a chat with a solicitor / local authority / trading standards etc, this is shocking, straight forward fraud.There should be some legal way of getting justice / compensation. |
24th Mar 2021 2:04am |
Yes I know.
24th Mar 2021 8:11am |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
The fact that you are getting a hard pedal with little travel suggests that there is not air in the system, it makes me think it is your servo that has failed and therefore not giving you any assistance. I could not say if this is something the garage has damaged or it is just a coincidence but the pedal feel is the same as when my servo started to leak 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
24th Mar 2021 9:01pm |
