Home > Technical (L405) > Deployable side steps.
Chasd
England 2016 Range Rover Autobiography SDV8 Carpathian Grey
Hi, Is it possible to leave the side steps deployed when the vehicle is parked and locked?
This is to protect the car from dings in the supermarket car park.
Thanks 2016 SDV8 Autobiography 😀
Gone :Disco4 Graphite,-Disco Sport .-(BMW X3) .-Disco4 XS .-Freelander 2 HSE
(Hyundai Santa Fe) .-Disco TD5 .-Disco TDi .-Defender 110 TDi 200
Post #588139 20th Mar 2021 12:09pm
West Yorks V8
Hi
I don’t think it is, after reading the steps info.
You can set the steps, to remain out..... but this is lost when you lock the car.
Hope this helps. Range Rover 4.4 SDV8 Autobiography
Land Rover Freelander 2 SD4
Range Rover P38 4.6
Range Rover Classic LSE 4.2 x 2
Range Rover Classic 3.9
Range Rover Classic 3.5
Post #588150 20th Mar 2021 2:06pm
scotsjon
United Kingdom 2016 Range Rover Autobiography SDV8 Farallon Black
I’d be worried about someone catching the sidesteps and doing some damage, they would be expensive to replace
J
Post #588330 21st Mar 2021 10:05pm
Kot
Interesting, today parked up near the local forest to exercise the family and the dog, and I was parked on a sideways incline.
The side steps didn't deploy when I got out, and the car was set on normal driving.
Must be an inclinometer fitted I thought. Grinning to myself thinking this car never stops to amaze me. Very Happy
Yet when I returned, they deployed when I opened the door as normal. Exclamation Question Its so clever lol
But agree it would be good to have a roof access mode, so you can wash the roof without having the door left open, or access roof rack etc 2018 SE SDV8 4.4 Byron Blue
Post #588571 23rd Mar 2021 4:45pm
this is from an old thread relating to the L322 but 'might' work on the L405,
1. TO LOCK STEPS OUT
➢ Do not start engine
➢ Press/release start/stop button to switch on ignition
➢ Depress/hold step button (driver�s lower console) for 5 seconds
➢ Warning light in switch illuminates and stays on
➢ Repeat to cancel
➢ Warning light in switch goes out
➢ Normal operation thereafter
2. TO LOCK STEPS IN
➢ Warning light in switch flashes twice
➢ Repeat to cancel
➢ Warning light in switch flashes three times
➢ Normal operation thereafter ... - .- -.
Post #588573 23rd Mar 2021 5:02pm
Kot
There is No button on MY18 L405 they operate automatically only on door opening and closing, its a software improvement maybe to be able to manually deploy them. 2018 SE SDV8 4.4 Byron Blue
Post #588876 25th Mar 2021 1:59pm
i think yours can be switched off/on and keep them out in the menu..select 'roof access' to keep them out.. ... - .- -.
Post #588878 25th Mar 2021 2:08pm
tomo141
Thats correct Stan, I came across it in mine. They stay out until you lock the car then they revert. ------------------------------------------
L460 D350 73 FFRR Autobiography Santorini Black with Shadow Pack
L405 4.4 V8 18 FFRR Autobiography (facelift) Santorini Black with Shadow Pack
L405 3.0 V6 13.5 FFRR Autobiography Santorini Black
L322 4.4 V8 12 FFRR Autobiography Santorini Black (RR Styling Pack)
L322 3.6 V8 10 FFRR Autobiography Santorini Black
L322 3.6 V8 07 FFRR Vogue SE Santorini Black
L322 3.0 I6 55 FFRR Autobiography Santorini Black
Post #589108 26th Mar 2021 9:15pm
Chasd
Thank you all for the information however the problem is they retract when the car is locked! Big Cry 2016 SDV8 Autobiography 😀
Post #589155 27th Mar 2021 5:58am
dazsear
I’m sure there is a way of putting the steps into roof access mode, I use it when I go to the car wash to stop them going in and out all the time.
Go to your side steps menu and select the mode. I’m sure you have to have the suspension dropped and be in park. Now open the drivers door and select the mode. Both steps will come out and stay out when you close the door.
I’m sure the mode will turn off once you raise the car or select drive. 2008 RRS HST - loved the car from 6 months old until a few years old
2009 Disco HSE - nice and practical alternative when I needed the space.
VW T5 Transporter - mid life crisis perhaps
2017 FFRR 4.4AB - best car I’ve ever owned
Post #595352 26th May 2021 6:17am
goddo
J
Interestingly, I have the fixed steps on mine and I have never caught anything on them or damaged them in any way. They do act as a buffer against car doors banging into mine! Very Happy Very Happy
Post #595358 26th May 2021 8:28am
