Home > Technical (L322) > Reduced performance P006A fault - solved |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Ive had a reduced performance fault come up since stripping down to do the idlers.
14th Mar 2021 5:29pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Hi Rob
14th Mar 2021 9:05pm |
Thanks for the advice gent's, I'll give the other sensor on doughnut a clean also.
15th Mar 2021 12:29pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3113 |
manifold inlet replace is a pig. it involves the injector leads coming off etc. Mine cost £1600 all in for pax side only. |
15th Mar 2021 1:12pm |
Let's hope it's not that then Dolphinboy!
17th Mar 2021 3:19pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3024 |
I'd say that's pretty well caked up. As far as I'm aware all of the little holes should be clear.
17th Mar 2021 3:34pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
mine had 2-3mm of crap on it when i cleaned it. I only cleaned it as i was changing the oil cooler and had no faults other than the customary oil leak.
17th Mar 2021 3:46pm |
Ok, so looks normal ISH!!
17th Mar 2021 3:53pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1182 |
I have to clean mine about every 2000 miles!! and it has far more on it than yours has. Thing is it still runs ok!! |
17th Mar 2021 4:13pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4278 |
I cleaned mine by spraying with brake cleaner until all 4 holes were clear. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
17th Mar 2021 4:37pm |
There is a separate thread somewhere about the throttle body fitting. Try taking the silver clip off and tightening it between fingers then refit it. I replaced the whole unit with a brand new one and it was still a little loose onto the ali throttle body Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silcon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
17th Mar 2021 4:39pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3736 |
I clean mine every 6 months at the same time I do the oil service, just as a way of remembering to do it.
17th Mar 2021 4:52pm |
Rob
17th Mar 2021 6:51pm |
Subject to being able to test drive it once I replace the front air springs & calliper I’ve hopefully found the issue.
1st Apr 2021 1:57pm |
