![]() | Home > Technical (L322) > Electrochromatic Mirrors Constantly Dimmed |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
I changed mine because of that. It was so bad to reverse in the dark. I understood that it supposed to like that they go "black" in the dark. And if the are too old/startto die, it gets worse- dark yellow most of the time. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3202 ![]() ![]() ![]() |
It's a pain in the dark, isn't it!
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1368 ![]() ![]() |
My passenger side mirror has gradually turned to a sepia colour, is this the same thing as your seeing or another issue? |
When the car detects someone following you it will dim the interior mirror and both door mirrors to stop the light dazzling you. When it does this the mirrors go a sort of green colour and when the lights stop being picked up the glass goes clear again.
A different problem then |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
David, sir yourself in the car and cover the little dot in the mirror glass, centre top??? Does this send them back clear? That sensor is the one that detects cars approaching from the rear! They are particularly sensitive to your interior lights! Second thing to try is a small torch and shine it on the sensor on the rear side of the mirror (remembering to turn off your interior lights!)... Does that work? |
Thanks for the suggestions, Craig. I'll give them a try when it's back from it's MOT |
Blanking the sensor on the front of the mirror doesn’t seem to make any difference but shining the light from my phone on the rear of the mirror does make them all go back to being clear again.
I need too try and get this sorted as now it's constantly dark, reversing is a nightmare.
I changed the rear view mirror on my car today and I don’t think it’s resolved the issue. I’ve not driven it yet but when starting it after a few seconds the mirrors dimmed again like before.
Just to close this out... changing my mirror has in fact resolved this issue.
