Home > Maintenance & Mods (L322) > L322 towbar electrics mounting plate |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Don't forget to seal the hell out of where it mounts to the body to stop water ingress. Known issue Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Mar 2021 2:47pm |
Yes, towing electric socket attaches to that 2 bolt bracket Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Mar 2021 2:48pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Just buy a generic plate and drill it to suit. Plenty come up on a Google search. Bish.
3rd Mar 2021 3:16pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 |
Thanks for the tip Dr Rob.
3rd Mar 2021 6:27pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3104 |
I bought a single towing socket bracket to fit the 13 pin electrics from Rob at Duckworths and it cost around 6 quid. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
7th Mar 2021 11:25pm |
lschwarcz Member Since: 18 May 2019 Location: Hillsboro, OR, USA Posts: 273 |
Here's the bracket in the picture of the whole wiring kit like I have on my USA model. The one for your car in the UK may be different. Here's a parts diagram from a European site that may show what you need. You'll need to take the number for the part (I think that's called the, "call out number") and Google for it. For example, I would Google for, "Land Rover 945509A" and look for a parts site that then lists the part number for that part. Then you can search for someplace that can get you the part!
You'll of course need to find what is the correct bracket for your connector. I'm guessing the UK will be different than here in the USA. Good luck! Larry. 2009 Range Rover L322 Autobiography Bournville/Ivory Save lives, give blood. |
8th Mar 2021 1:35am |
Hi Larry, thanks for this detailed information. That bracket looks like it's exactly the item I need! I'll see whether I can track one down over here, that's really useful, thanks again. 5.0 S/C Autobiography - now gone to pastures new.... |
8th Mar 2021 9:18am |
Quick update: Rob at Duckworths cross-referenced the part number and I have one on order for a whole £6-ish! 5.0 S/C Autobiography - now gone to pastures new.... |
9th Mar 2021 9:50pm |
