Home > Maintenance & Mods (L322) > Diesel - premium or standard 4.4tdv8
Page 4 of 4 <1234
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
I think the small print get out clause is there for a very good reason "Actual effects and benefits may vary according to vehicle type, driving conditions and driving style." BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #582708 7th Feb 2021 5:48pm
LT
Someone should do an identical bench test comparison.
Post #582711 7th Feb 2021 6:03pm
dingg1
Because they even put a disclaimer in
No guarantees provided
Laughing
4Measured using industry standard and Shell proprietary tests. Helps to protect key fuel system components such as intake valves and/or fuel injectors from the build up of performance robbing deposits. Actual effects and benefits may vary according to vehicle type, driving conditions and driving style. No guarantees provided. See shell.co.uk/vpower for more information.
Post #582714 7th Feb 2021 6:39pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Disclaimers don’t get you off the hook. Just like clauses in terms and condition contrary to super rights don’t provide a waiver for those rights.
Post #582718 7th Feb 2021 6:49pm
dingg1
Good luck to anyone taking up a legal action against a major oil company
Rolling Eyes
Post #582722 7th Feb 2021 7:09pm
V8_Disco
Shocked What did I start!
As others have said some strong views, my only
Comment is Range Rovers and Africa etc, run on anything - not going to try that on my 4.4, these engines are a hell of a long way from a VM or 2/300tdi - for me in a good way
Post #582724 7th Feb 2021 7:15pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
The base fuel is all essentially the same (given it all meets the same standard and is only refined in a handful of locations), it’s about the additives added afterwards.
Post #582728 7th Feb 2021 8:31pm
LT
^ That’s my understanding of it. The question is do these additives make a difference?
I can’t prove it, but I think I get a tad more mpg on regular Shell diesel than I do on supermarket diesel.
Post #582735 7th Feb 2021 9:21pm
Wouldn’t fancy running a 4.4 in Africa. The sulphur levels in African fuels can be much higher which can clog DPFs more quickly. It’s one of the reasons some country’s fatties are specced less a DPF filter.
https://wedocs.unep.org/bitstream/handle/2...isAllowed= There is nothing that can't be fixed with a hammer😜😜
Post #582737 7th Feb 2021 9:26pm
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
My wife’s car is listed for 98ron, but I do wonder with all of the lock downs how much that stuff now sits in the tanks compared to standard 95....
Post #582747 7th Feb 2021 10:17pm
Page 4 of 4 <1234
