Home > Maintenance & Mods (L322) > Rear washer issue |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3741 |
Try changing the non return valve.
1st Feb 2021 4:53pm |
Dode4444 Member Since: 18 Jan 2021 Location: Buckie Posts: 43 |
Thanks, will look in to this. Would a faulty NRV cause a leak though? 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
1st Feb 2021 5:35pm |
It can cause both of your problems.
1st Feb 2021 5:48pm |
Thanks.
1st Feb 2021 6:14pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 599 |
my 2005 does this its a pain in the ass hardly bother using any more just let the rain cleen it |
1st Feb 2021 6:55pm |
That’s exactly what I’ve done the last 200 miles or so 2005 (55) Range Rover 4.2 Supercharged Vogue SE Java Black |
1st Feb 2021 7:44pm |
Jri711 Member Since: 26 Feb 2019 Location: Norfolk Posts: 20 |
I have the same problem on mine, would you know where the valve is located? |
1st Feb 2021 8:48pm |
1st Feb 2021 9:04pm |
Would something similar to these be ok instead of the £10-15 genuine part, these are around £2-3 if they do the same job?
5th Feb 2021 2:34am |
They would be fine, just make sure to fit it the correct way round.
5th Feb 2021 9:30am |
Perfect.
5th Feb 2021 10:01am |
