Home > Maintenance & Mods (L322) > Help for a noob thicky!..fbh fuse
Dstew
I have a 2011 4.4 TDV8 Vogue SE
I would really like to pull the FBH fuse but can't seem to find a definitive answer as to which one it is or where it is.
Pretend for a moment I'm not even sure where all the fuse boxes are although I think there is one in the right hand side of the boot.
Please can someone confirm what number fuse it is and where I will actually find it for my model year?
Thanks in advance.
David
Post #581634 29th Jan 2021 4:46pm
Andy B
There is a thread here that may help?
https://www.fullfatrr.com/forum/topic36096...t=fbh+fuse SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #581641 29th Jan 2021 5:14pm
Dstew
Thanks but there are so any different opinions on that thread with no definitive answer.
Post #581651 29th Jan 2021 6:30pm
mjdronfield
The electrical diagrams detail a fuse for the FBH and a fuse for the receiver, if you need that specifically. Can’t help with fuse location I’m afraid.
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #581656 29th Jan 2021 7:08pm
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
Just disconnect the battery. You will need a 10mm spanner.
Post #581669 29th Jan 2021 8:16pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
If you’re removing the fuse to pair the fob, no need - remove the right hand compartment cover in the boot, you will see a black module around the size of cigarette packet with a Webasto sticker on it, remove the black connector, it’s quite stiff but will just pull out. Leave disconnected for 10 seconds, replace and immediately press & hold the off button on the fob, the red led on the fob will illuminate then go out, pairing is then complete.
Post #581670 29th Jan 2021 8:32pm
Dstew
Thanks for your answer but I want to do a FBH reset. Also I would rather not disconnect the battery and have to reset clock, steering, windows etc
Post #581701 30th Jan 2021 9:22am
rjff
The WM does say battery disconnect to reset the FBH. But try MJD's fuse suggestion to see if it works.
I don't think the steering has to be reset on an 11MY, windows and clock are simple! Cheers
Richard
Gap IIDBT
Post #581736 30th Jan 2021 12:56pm
Dstew
Where would I find junction box engine?
Post #581745 30th Jan 2021 1:24pm
Baltic Blue
I don’t know why but it is always the folding mirrors on mine that get out of sync, but opening and closing the drivers door a few times usually sorts it.
Post #581749 30th Jan 2021 1:37pm
mjdronfield
On this page, it says Fuse 59.... in the glove box is FBH......
https://fusesdiagram.com/range-rover/fuses...-2012.html
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #581754 30th Jan 2021 2:11pm
