Home > Maintenance & Mods (L322) > Help for a noob thicky!..fbh fuse |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
There is a thread here that may help?
29th Jan 2021 4:14pm |
Dstew Member Since: 26 Dec 2020 Location: Kent Posts: 41 |
Thanks but there are so any different opinions on that thread with no definitive answer. |
29th Jan 2021 5:30pm |
The electrical diagrams detail a fuse for the FBH and a fuse for the receiver, if you need that specifically. Can’t help with fuse location I’m afraid.
29th Jan 2021 6:08pm |
Bluespanner Member Since: 03 Jan 2021 Location: Burton up on Trent Posts: 43 |
Just disconnect the battery. You will need a 10mm spanner. |
29th Jan 2021 7:16pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 863 |
If you’re removing the fuse to pair the fob, no need - remove the right hand compartment cover in the boot, you will see a black module around the size of cigarette packet with a Webasto sticker on it, remove the black connector, it’s quite stiff but will just pull out. Leave disconnected for 10 seconds, replace and immediately press & hold the off button on the fob, the red led on the fob will illuminate then go out, pairing is then complete. |
29th Jan 2021 7:32pm |
Thanks for your answer but I want to do a FBH reset. Also I would rather not disconnect the battery and have to reset clock, steering, windows etc |
30th Jan 2021 8:22am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
The WM does say battery disconnect to reset the FBH. But try MJD's fuse suggestion to see if it works.
30th Jan 2021 11:56am |
Where would I find junction box engine? |
30th Jan 2021 12:24pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3765 |
I don’t know why but it is always the folding mirrors on mine that get out of sync, but opening and closing the drivers door a few times usually sorts it.
30th Jan 2021 12:37pm |
On this page, it says Fuse 59.... in the glove box is FBH......
30th Jan 2021 1:11pm |
